Dual gfx cards: DRM + FBDEV
sailorMH
Post by sailorMH »
I slowly rebulding my computer corner and now I have four computers connected via KVM switch with two mohitors.
On my X1000 I had gfx card HD 7970 ( CGN 1, Southern Island, Tahiti ) for AmigaOS and FirePro V7900 ( TeraScale 3, Northern Islands Cayman ) for linux. Now with two monitors connected I tried to connect both my cards. Of course, HD7970 has no acceleration under linux so I made this xorg.conf:
Section "ServerLayout"
	Identifier     "X.org Configured"
	Screen      0  "Screen0" 0 0
	Screen      1  "Screen1" RightOf "Screen0"
	InputDevice    "Mouse0" "CorePointer"
	InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
Section "Files"
	ModulePath   "/usr/lib/xorg/modules"
	FontPath     "/usr/share/fonts/X11/misc"
	FontPath     "/usr/share/fonts/X11/cyrillic"
	FontPath     "/usr/share/fonts/X11/100dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/75dpi/:unscaled"
	FontPath     "/usr/share/fonts/X11/Type1"
	FontPath     "/usr/share/fonts/X11/100dpi"
	FontPath     "/usr/share/fonts/X11/75dpi"
	FontPath     "built-ins"
EndSection
#Section "Module"
#	Load  "glx"
#EndSection
Section "InputDevice"
	Identifier  "Keyboard0"
	Driver      "kbd"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
	Option	    "Protocol" "auto"
	Option	    "Device" "/dev/input/mice"
	Option	    "ZAxisMapping" "4 5 6 7"
EndSection
Section "Monitor"
	Identifier   "Monitor0"
	VendorName   "Monitor Vendor"
	ModelName    "Monitor Model"
EndSection
Section "Monitor"
	Identifier   "Monitor1"
EndSection
Section "Device"
        ### Available Driver options are:-
        ### Values: <i>: integer, <f>: float, <bool>: "True"/"False",
        ### <string>: "String", <freq>: "<f> Hz/kHz/MHz",
        ### <percent>: "<f>%"
        ### [arg]: arg optional
        #Option     "Accel"              	# [<bool>]
        #Option     "SWcursor"           	# [<bool>]
        #Option     "EnablePageFlip"     	# [<bool>]
        #Option     "ColorTiling"        	# [<bool>]
        #Option     "ColorTiling2D"      	# [<bool>]
        #Option     "RenderAccel"        	# [<bool>]
        #Option     "SubPixelOrder"      	# [<str>]
        #Option     "AccelMethod"        	# <str>
        #Option     "EXAVSync"           	# [<bool>]
        #Option     "EXAPixmaps"         	# [<bool>]
        #Option     "ZaphodHeads"        	# <str>
        #Option     "SwapbuffersWait"    	# [<bool>]
	Identifier  "Card0"
	Driver      "radeon"
	BusID       "PCI:1:0:0"
EndSection
Section "Device"
        Option     "AccelMethod"        	"none"
	Option      "DRI"			"none"
	Identifier  "Card1"
	Driver      "fbdev"
	BusID       "PCI:3:0:0"
EndSection
Section "Screen"
	Identifier "Screen0"
	Device     "Card0"
	Monitor    "Monitor0"
	SubSection "Display"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
Section "Screen"
	Identifier "Screen1"
	Device     "Card1"
	Monitor    "Monitor1"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
I tried also comment Section "Module" Load "glx", but effect is the same
X starts, it running but I see only black screen. This is the log:
[   268.130]
X.Org X Server 1.21.1.7
X Protocol Version 11, Revision 0
[   268.164] Current Operating System: Linux amigaone 6.12.76-powerpc64-smp #1 SMP Sat Mar  7 05:21:52 UTC 2026 ppc64
[   268.164] Kernel command line: root=/dev/sdb5 rootdelay=5
[   268.188] xorg-server 2:21.1.7-3 (https://www.debian.org/support)
[   268.201] Current version of pixman: 0.42.2
[   268.226] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[   268.226] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   268.277] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jun 17 18:33:41 2026
[   268.291] (++) Using config file: "./xorg.conf.new"
[   268.304] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   268.318] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   268.319] (==) ServerLayout "X.org Configured"
[   268.319] (**) |-->Screen "Screen0" (0)
[   268.320] (**) |   |-->Monitor "Monitor0"
[   268.320] (**) |   |-->Device "Card0"
[   268.320] (**) |-->Screen "Screen1" (1)
[   268.320] (**) |   |-->Monitor "Monitor1"
[   268.321] (**) |   |-->Device "Card1"
[   268.321] (**) |-->Input Device "Mouse0"
[   268.321] (**) |-->Input Device "Keyboard0"
[   268.321] (==) Automatically adding devices
[   268.321] (==) Automatically enabling devices
[   268.321] (==) Automatically adding GPU devices
[   268.321] (==) Automatically binding GPU devices
[   268.321] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   268.321] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   268.321] 	Entry deleted from font path.
[   268.321] (**) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/100dpi/:unscaled,
	/usr/share/fonts/X11/75dpi/:unscaled,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins,
	built-ins
[   268.321] (**) ModulePath set to "/usr/lib/xorg/modules"
[   268.321] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[   268.321] (WW) Disabling Mouse0
[   268.321] (WW) Disabling Keyboard0
[   268.321] (II) Loader magic: 0x123f02d88
[   268.321] (II) Module ABI versions:
[   268.321] 	X.Org ANSI C Emulation: 0.4
[   268.321] 	X.Org Video Driver: 25.2
[   268.321] 	X.Org XInput driver : 24.4
[   268.321] 	X.Org Server Extension : 10.0
[   268.324] (--) using VT number 2
[   268.324] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   268.328] (II) xfree86: Adding drm device (/dev/dri/card0)
[   268.328] (II) Platform probe for /sys/devices/pci0000:00/0000:00:10.0/0000:01:00.0/drm/card0
[   268.330] (II) xfree86: Adding drm device (/dev/dri/card1)
[   268.330] (II) Platform probe for /sys/devices/pci0000:00/0000:00:10.2/0000:03:00.0/drm/card1
[   268.345] (!!) More than one possible primary device found
[   268.345] (--) PCI: (1@0:0:0) 1002:6704:1002:0b00 rev 0, Mem @ 0x90000000/268435456, 0xa0020000/131072, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[   268.345] (--) PCI: (3@0:0:0) 1002:6798:1682:3212 rev 0, Mem @ 0xb0000000/268435456, 0xc0000000/262144, I/O @ 0x00003000/256, BIOS @ 0x????????/131072
[   268.346] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[   268.346] (II) LoadModule: "glx"
[   268.346] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   268.349] (II) Module glx: vendor="X.Org Foundation"
[   268.349] 	compiled for 1.21.1.7, module version = 1.0.0
[   268.350] 	ABI class: X.Org Server Extension, version 10.0
[   268.350] (II) LoadModule: "radeon"
[   268.350] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[   268.351] (II) Module radeon: vendor="X.Org Foundation"
[   268.351] 	compiled for 1.21.1.3, module version = 19.1.0
[   268.351] 	Module class: X.Org Video Driver
[   268.351] 	ABI class: X.Org Video Driver, version 25.2
[   268.352] (II) LoadModule: "fbdev"
[   268.352] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[   268.352] (II) Module fbdev: vendor="X.Org Foundation"
[   268.352] 	compiled for 1.21.1.3, module version = 0.5.0
[   268.352] 	Module class: X.Org Video Driver
[   268.352] 	ABI class: X.Org Video Driver, version 25.2
[   268.352] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
	ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
	ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
	ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
	ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
	ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
	ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
	ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
	ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
	ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
	ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
	ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
	ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
	ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
	ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
	ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
	ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
	ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
	ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
	ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
	ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
	ATI Radeon 9800PRO, ATI Radeon 9800XT,
	ATI Radeon Mobility 9600/9700 (M10/M11),
	ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
	ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
	ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
	ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
	ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
	ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
	ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
	ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
	ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
	ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
	ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
	ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
	ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
	ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
	ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
	ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
	ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
	ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
	ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
	ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
	ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
	ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
	ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
	ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
	ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
	ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
	ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
	ATI FireGL V3350, ATI Mobility Radeon X1450,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
	ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
	ATI FireGL V3400, ATI Mobility FireGL V5250,
	ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
	ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
	ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
	ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
	ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
	ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
	ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
	ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
	ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
	ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
	AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
	ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
	ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
	ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
	ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
	ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
	ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
	ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
	ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
	ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
	ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
	ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
	ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
	ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
	ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
	ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
	ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
	ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
	ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE,
	ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
	ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
	ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
	ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
	ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
	ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
	ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
	AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
	AMD Radeon HD 6300 Series Graphics,
	AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
	ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
	AMD Firestream 9350, ATI Radeon HD 5800 Series,
	ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
	ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
	ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
	ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
	REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
	ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
	AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
	AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
	ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
	MULLINS, KAVERI, HAWAII
[   268.356] (II) FBDEV: driver for framebuffer: fbdev
[   268.465] (II) [KMS] Kernel modesetting enabled.
[   268.465] (II) Loading sub module "fbdevhw"
[   268.465] (II) LoadModule: "fbdevhw"
[   268.465] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[   268.465] (II) Module fbdevhw: vendor="X.Org Foundation"
[   268.465] 	compiled for 1.21.1.7, module version = 0.0.2
[   268.465] 	ABI class: X.Org Video Driver, version 25.2
[   268.465] (**) FBDEV(1): claimed PCI slot 3@0:0:0
[   268.465] (II) FBDEV(1): using default device
[   268.465] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[   268.465] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[   268.465] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[   268.465] (==) RADEON(0): Default visual is TrueColor
[   268.466] (**) RADEON(0): Option "Accel" "True"
[   268.466] (==) RADEON(0): RGB weight 888
[   268.466] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[   268.466] (--) RADEON(0): Chipset: "CAYMAN" (ChipID = 0x6704)
[   268.466] (II) Loading sub module "fb"
[   268.466] (II) LoadModule: "fb"
[   268.466] (II) Module "fb" already built-in
[   268.466] (II) Loading sub module "dri2"
[   268.466] (II) LoadModule: "dri2"
[   268.466] (II) Module "dri2" already built-in
[   268.590] (II) Loading sub module "glamoregl"
[   268.591] (II) LoadModule: "glamoregl"
[   268.591] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[   268.609] (II) Module glamoregl: vendor="X.Org Foundation"
[   268.609] 	compiled for 1.21.1.7, module version = 1.0.1
[   268.609] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   268.640] (II) RADEON(0): glamor X acceleration enabled on AMD CAYMAN (DRM 2.50.0 / 6.12.76-powerpc64-smp, LLVM 15.0.7)
[   268.640] (II) RADEON(0): glamor detected, initialising EGL layer.
[   268.640] (II) RADEON(0): KMS Color Tiling: enabled
[   268.640] (II) RADEON(0): KMS Color Tiling 2D: enabled
[   268.640] (==) RADEON(0): TearFree property default: auto
[   268.640] (II) RADEON(0): KMS Pageflipping: enabled
[   268.662] (II) RADEON(0): Output DisplayPort-0 using monitor section Monitor0
[   268.679] (II) RADEON(0): Output DisplayPort-1 has no monitor section
[   268.700] (II) RADEON(0): Output DisplayPort-2 has no monitor section
[   268.721] (II) RADEON(0): Output DisplayPort-3 has no monitor section
[   268.742] (II) RADEON(0): EDID for output DisplayPort-0
[   268.758] (II) RADEON(0): EDID for output DisplayPort-1
[   268.758] (II) RADEON(0): Manufacturer: BNQ  Model: 7f11  Serial#: 21573
[   268.758] (II) RADEON(0): Year: 2013  Week: 3
[   268.758] (II) RADEON(0): EDID Version: 1.3
[   268.758] (II) RADEON(0): Digital Display Input
[   268.758] (II) RADEON(0): Max Image Size [cm]: horiz.: 53  vert.: 30
[   268.758] (II) RADEON(0): Gamma: 2.20
[   268.758] (II) RADEON(0): DPMS capabilities: Off
[   268.758] (II) RADEON(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[   268.758] (II) RADEON(0): Default color space is primary color space
[   268.758] (II) RADEON(0): First detailed timing is preferred mode
[   268.758] (II) RADEON(0): redX: 0.649 redY: 0.328   greenX: 0.330 greenY: 0.621
[   268.758] (II) RADEON(0): blueX: 0.150 blueY: 0.053   whiteX: 0.312 whiteY: 0.328
[   268.758] (II) RADEON(0): Supported established timings:
[   268.758] (II) RADEON(0): 720x400@70Hz
[   268.758] (II) RADEON(0): 640x480@60Hz
[   268.758] (II) RADEON(0): 640x480@75Hz
[   268.758] (II) RADEON(0): 800x600@60Hz
[   268.758] (II) RADEON(0): 800x600@75Hz
[   268.758] (II) RADEON(0): 832x624@75Hz
[   268.758] (II) RADEON(0): 1024x768@60Hz
[   268.758] (II) RADEON(0): 1024x768@75Hz
[   268.758] (II) RADEON(0): 1280x1024@75Hz
[   268.758] (II) RADEON(0): 1152x864@75Hz
[   268.758] (II) RADEON(0): Manufacturer's mask: 0
[   268.758] (II) RADEON(0): Supported standard timings:
[   268.758] (II) RADEON(0): #0: hsize: 640  vsize 480  refresh: 100  vid: 26673
[   268.758] (II) RADEON(0): #1: hsize: 640  vsize 480  refresh: 120  vid: 31793
[   268.758] (II) RADEON(0): #2: hsize: 800  vsize 600  refresh: 100  vid: 26693
[   268.758] (II) RADEON(0): #3: hsize: 800  vsize 600  refresh: 120  vid: 31813
[   268.759] (II) RADEON(0): #4: hsize: 1024  vsize 768  refresh: 100  vid: 26721
[   268.759] (II) RADEON(0): #5: hsize: 1024  vsize 768  refresh: 120  vid: 31841
[   268.759] (II) RADEON(0): #6: hsize: 1440  vsize 900  refresh: 120  vid: 15509
[   268.759] (II) RADEON(0): #7: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[   268.759] (II) RADEON(0): Supported detailed timing:
[   268.759] (II) RADEON(0): clock: 148.5 MHz   Image Size:  531 x 298 mm
[   268.759] (II) RADEON(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[   268.759] (II) RADEON(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[   268.759] (II) RADEON(0): Serial No: 51D01957SL0
[   268.759] (II) RADEON(0): Ranges: V min: 24 V max: 120 Hz, H min: 15 H max: 135 kHz, PixClock max 175 MHz
[   268.759] (II) RADEON(0): Monitor name: BenQ XL2411T
[   268.759] (II) RADEON(0): clock: 74.2 MHz   Image Size:  531 x 298 mm
[   268.759] (II) RADEON(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[   268.759] (II) RADEON(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[   268.759] (II) RADEON(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[   268.759] (II) RADEON(0): clock: 27.0 MHz   Image Size:  531 x 298 mm
[   268.759] (II) RADEON(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[   268.759] (II) RADEON(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[   268.759] (II) RADEON(0): Number of EDID sections to follow: 1
[   268.759] (II) RADEON(0): EDID (in hex):
[   268.759] (II) RADEON(0): 	00ffffffffffff0009d1117f45540000
[   268.759] (II) RADEON(0): 	0317010380351e782e48a0a654549f26
[   268.759] (II) RADEON(0): 	0d5054a56b803168317c4568457c6168
[   268.759] (II) RADEON(0): 	617c953cd1c0023a801871382d40582c
[   268.759] (II) RADEON(0): 	4500132a2100001e000000ff00353144
[   268.759] (II) RADEON(0): 	3031393537534c300a20000000fd0018
[   268.759] (II) RADEON(0): 	780f8711000a202020202020000000fc
[   268.759] (II) RADEON(0): 	0042656e5120584c32343131540a0152
[   268.759] (II) RADEON(0): 	020323f1509005040302011112131406
[   268.759] (II) RADEON(0): 	0715161f20230907078301000065030c
[   268.759] (II) RADEON(0): 	001200011d8018711c1620582c250013
[   268.759] (II) RADEON(0): 	2a2100009f011d007251d01e206e2855
[   268.759] (II) RADEON(0): 	00132a2100001f8c0ad08a20e02d1010
[   268.759] (II) RADEON(0): 	3e9600132a2100001900000000000000
[   268.759] (II) RADEON(0): 	00000000000000000000000000000000
[   268.759] (II) RADEON(0): 	000000000000000000000000000000f5
[   268.760] (--) RADEON(0): HDMI max TMDS frequency 145000KHz
[   268.760] (II) RADEON(0): Not using mode "1440x900" (bad mode clock/interlace/doublescan)
[   268.760] (II) RADEON(0): Printing probed modes for output DisplayPort-1
[   268.760] (II) RADEON(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[   268.760] (II) RADEON(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   268.760] (II) RADEON(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[   268.760] (II) RADEON(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[   268.760] (II) RADEON(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[   268.760] (II) RADEON(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[   268.760] (II) RADEON(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[   268.760] (II) RADEON(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[   268.760] (II) RADEON(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   268.760] (II) RADEON(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   268.760] (II) RADEON(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   268.760] (II) RADEON(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[   268.760] (II) RADEON(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   268.760] (II) RADEON(0): Modeline "1024x768"x120.0  115.50  1024 1072 1104 1184  768 771 775 813 +hsync -vsync (97.6 kHz e)
[   268.760] (II) RADEON(0): Modeline "1024x768"x100.0  113.27  1024 1096 1208 1392  768 769 772 814 -hsync +vsync (81.4 kHz)
[   268.760] (II) RADEON(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   268.760] (II) RADEON(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   268.760] (II) RADEON(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   268.760] (II) RADEON(0): Modeline "800x600"x120.0   73.25  800 848 880 960  600 603 607 636 +hsync -vsync (76.3 kHz e)
[   268.760] (II) RADEON(0): Modeline "800x600"x100.0   68.17  800 848 936 1072  600 601 604 636 -hsync +vsync (63.6 kHz)
[   268.760] (II) RADEON(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   268.760] (II) RADEON(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   268.760] (II) RADEON(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[   268.760] (II) RADEON(0): Modeline "720x576i"x50.0   13.50  720 732 795 864  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[   268.760] (II) RADEON(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   268.760] (II) RADEON(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   268.760] (II) RADEON(0): Modeline "720x480i"x60.0   13.51  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[   268.760] (II) RADEON(0): Modeline "720x480i"x59.9   13.50  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[   268.760] (II) RADEON(0): Modeline "640x480"x120.0   52.40  640 680 744 848  480 481 484 515 -hsync +vsync (61.8 kHz)
[   268.760] (II) RADEON(0): Modeline "640x480"x100.0   43.16  640 680 744 848  480 481 484 509 -hsync +vsync (50.9 kHz)
[   268.760] (II) RADEON(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   268.760] (II) RADEON(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   268.760] (II) RADEON(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   268.760] (II) RADEON(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   268.781] (II) RADEON(0): EDID for output DisplayPort-2
[   268.802] (II) RADEON(0): EDID for output DisplayPort-3
[   268.802] (II) RADEON(0): Output DisplayPort-0 disconnected
[   268.802] (II) RADEON(0): Output DisplayPort-1 connected
[   268.802] (II) RADEON(0): Output DisplayPort-2 disconnected
[   268.802] (II) RADEON(0): Output DisplayPort-3 disconnected
[   268.802] (II) RADEON(0): Using exact sizes for initial modes
[   268.802] (II) RADEON(0): Output DisplayPort-1 using initial mode 1920x1080 +0+0
[   268.802] (II) RADEON(0): mem size init: gart size :3fdce000 vram size: s:80000000 visible:f4b4000
[   268.802] (==) RADEON(0): DPI set to (96, 96)
[   268.802] (==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
[   268.802] (II) Loading sub module "ramdac"
[   268.802] (II) LoadModule: "ramdac"
[   268.802] (II) Module "ramdac" already built-in
[   268.803] (==) FBDEV(1): Depth 24, (==) framebuffer bpp 32
[   268.803] (==) FBDEV(1): RGB weight 888
[   268.803] (==) FBDEV(1): Default visual is TrueColor
[   268.803] (==) FBDEV(1): Using gamma correction (1.0, 1.0, 1.0)
[   268.803] (II) FBDEV(1): hardware: radeondrmfb (video memory: 14400kB)
[   268.803] (II) FBDEV(1): checking modes against framebuffer device...
[   268.803] (II) FBDEV(1): checking modes against monitor...
[   268.803] (II) FBDEV(1): Virtual size is 2560x1440 (pitch 2560)
[   268.803] (**) FBDEV(1):  Built-in mode "current"
[   268.803] (==) FBDEV(1): DPI set to (96, 96)
[   268.803] (II) Loading sub module "fb"
[   268.803] (II) LoadModule: "fb"
[   268.803] (II) Module "fb" already built-in
[   268.803] (**) FBDEV(1): using shadow framebuffer
[   268.803] (II) Loading sub module "shadow"
[   268.803] (II) LoadModule: "shadow"
[   268.803] (II) Loading /usr/lib/xorg/modules/libshadow.so
[   268.803] (II) Module shadow: vendor="X.Org Foundation"
[   268.803] 	compiled for 1.21.1.7, module version = 1.1.0
[   268.804] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   268.804] (II) RADEON(0): [DRI2] Setup complete
[   268.804] (II) RADEON(0): [DRI2]   DRI driver: r600
[   268.804] (II) RADEON(0): [DRI2]   VDPAU driver: r600
[   268.804] (II) RADEON(0): Front buffer size: 8100K
[   268.804] (II) RADEON(0): VRAM usage limit set to 218142K
[   268.804] (II) RADEON(0): SYNC extension fences enabled
[   268.804] (II) RADEON(0): Present extension enabled
[   268.805] (==) RADEON(0): DRI3 enabled
[   268.805] (==) RADEON(0): Backing store enabled
[   268.805] (II) RADEON(0): Direct rendering enabled
[   268.879] (II) RADEON(0): Use GLAMOR acceleration.
[   268.879] (II) RADEON(0): Acceleration enabled
[   268.879] (==) RADEON(0): DPMS enabled
[   268.879] (==) RADEON(0): Silken mouse enabled
[   268.879] (II) RADEON(0): Set up textured video (glamor)
[   268.879] (II) RADEON(0): [XvMC] Associated with GLAMOR Textured Video.
[   268.879] (II) RADEON(0): [XvMC] Extension initialized.
[   268.947] (==) FBDEV(1): Backing store enabled
[   268.947] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[   268.948] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[   268.949] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[   268.950] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[   268.951] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[   268.952] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[   268.952] (==) FBDEV(1): DPMS enabled
[   268.952] (II) Initializing extension Generic Event Extension
[   268.953] (II) Initializing extension SHAPE
[   268.953] (II) Initializing extension MIT-SHM
[   268.954] (II) Initializing extension XInputExtension
[   268.955] (II) Initializing extension XTEST
[   268.955] (II) Initializing extension BIG-REQUESTS
[   268.956] (II) Initializing extension SYNC
[   268.957] (II) Initializing extension XKEYBOARD
[   268.957] (II) Initializing extension XC-MISC
[   268.958] (II) Initializing extension SECURITY
[   268.959] (II) Initializing extension XFIXES
[   268.959] (II) Initializing extension RENDER
[   268.960] (II) Initializing extension RANDR
[   268.961] (II) Initializing extension COMPOSITE
[   268.961] (II) Initializing extension DAMAGE
[   268.962] (II) Initializing extension MIT-SCREEN-SAVER
[   268.963] (II) Initializing extension DOUBLE-BUFFER
[   268.963] (II) Initializing extension RECORD
[   268.964] (II) Initializing extension DPMS
[   268.965] (II) Initializing extension Present
[   268.965] (II) Initializing extension DRI3
[   268.966] (II) Initializing extension X-Resource
[   268.966] (II) Initializing extension XVideo
[   268.967] (II) Initializing extension XVideo-MotionCompensation
[   268.968] (II) Initializing extension SELinux
[   268.968] (II) SELinux: Disabled on system
[   268.968] (II) Initializing extension GLX
[   268.986] (II) AIGLX: Loaded and initialized r600
[   268.986] (II) GLX: Initialized DRI2 GL provider for screen 0
[   268.986] (II) AIGLX: Screen 1 is not DRI2 capable
[   269.008] (II) IGLX: Loaded and initialized swrast
[   269.008] (II) GLX: Initialized DRISWRAST GL provider for screen 1
[   269.008] (II) Initializing extension XFree86-VidModeExtension
[   269.009] (II) Initializing extension XFree86-DGA
[   269.009] (II) Initializing extension XFree86-DRI
[   269.009] (II) Initializing extension DRI2
[   269.011] (II) RADEON(0): Setting screen physical size to 508 x 285
[   269.254] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/event0)
[   269.254] (**) ATEN HDMI KVM: Applying InputClass "libinput keyboard catchall"
[   269.254] (II) LoadModule: "libinput"
[   269.255] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   269.260] (II) Module libinput: vendor="X.Org Foundation"
[   269.260] 	compiled for 1.21.1.3, module version = 1.2.1
[   269.260] 	Module class: X.Org XInput Driver
[   269.260] 	ABI class: X.Org XInput driver, version 24.4
[   269.260] (II) Using input driver 'libinput' for 'ATEN HDMI KVM'
[   269.260] (**) ATEN HDMI KVM: always reports core events
[   269.260] (**) Option "Device" "/dev/input/event0"
[   269.271] (II) event0  - ATEN HDMI KVM: is tagged by udev as: Keyboard
[   269.271] (II) event0  - ATEN HDMI KVM: device is a keyboard
[   269.271] (II) event0  - ATEN HDMI KVM: device removed
[   269.285] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.0/0003:0557:222E.0001/input/input0/event0"
[   269.285] (II) XINPUT: Adding extended input device "ATEN HDMI KVM" (type: KEYBOARD, id 6)
[   269.285] (**) Option "xkb_model" "pc105"
[   269.285] (**) Option "xkb_layout" "us"
[   269.291] (II) event0  - ATEN HDMI KVM: is tagged by udev as: Keyboard
[   269.291] (II) event0  - ATEN HDMI KVM: device is a keyboard
[   269.294] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/event1)
[   269.294] (**) ATEN HDMI KVM: Applying InputClass "libinput pointer catchall"
[   269.294] (II) Using input driver 'libinput' for 'ATEN HDMI KVM'
[   269.294] (**) ATEN HDMI KVM: always reports core events
[   269.294] (**) Option "Device" "/dev/input/event1"
[   269.350] (II) event1  - ATEN HDMI KVM: is tagged by udev as: Mouse
[   269.351] (II) event1  - ATEN HDMI KVM: device is a pointer
[   269.351] (II) event1  - ATEN HDMI KVM: device removed
[   269.384] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.1/0003:0557:222E.0002/input/input1/event1"
[   269.384] (II) XINPUT: Adding extended input device "ATEN HDMI KVM" (type: MOUSE, id 7)
[   269.384] (**) Option "AccelerationScheme" "none"
[   269.384] (**) ATEN HDMI KVM: (accel) selected scheme none/0
[   269.384] (**) ATEN HDMI KVM: (accel) acceleration factor: 2.000
[   269.384] (**) ATEN HDMI KVM: (accel) acceleration threshold: 4
[   269.440] (II) event1  - ATEN HDMI KVM: is tagged by udev as: Mouse
[   269.441] (II) event1  - ATEN HDMI KVM: device is a pointer
[   269.443] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/mouse0)
[   269.444] (II) No input driver specified, ignoring this device.
[   269.444] (II) This device may have been added with another device file.
[   269.447] (II) config/udev: Adding input device ATEN HDMI KVM Keyboard (/dev/input/event2)
[   269.447] (**) ATEN HDMI KVM Keyboard: Applying InputClass "libinput keyboard catchall"
[   269.447] (II) Using input driver 'libinput' for 'ATEN HDMI KVM Keyboard'
[   269.447] (**) ATEN HDMI KVM Keyboard: always reports core events
[   269.447] (**) Option "Device" "/dev/input/event2"
[   269.452] (II) event2  - ATEN HDMI KVM Keyboard: is tagged by udev as: Keyboard
[   269.452] (II) event2  - ATEN HDMI KVM Keyboard: device is a keyboard
[   269.453] (II) event2  - ATEN HDMI KVM Keyboard: device removed
[   269.462] (II) libinput: ATEN HDMI KVM Keyboard: needs a virtual subdevice
[   269.462] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.2/0003:0557:222E.0003/input/input2/event2"
[   269.462] (II) XINPUT: Adding extended input device "ATEN HDMI KVM Keyboard" (type: MOUSE, id 8)
[   269.462] (**) Option "AccelerationScheme" "none"
[   269.462] (**) ATEN HDMI KVM Keyboard: (accel) selected scheme none/0
[   269.462] (**) ATEN HDMI KVM Keyboard: (accel) acceleration factor: 2.000
[   269.462] (**) ATEN HDMI KVM Keyboard: (accel) acceleration threshold: 4
[   269.467] (II) event2  - ATEN HDMI KVM Keyboard: is tagged by udev as: Keyboard
[   269.468] (II) event2  - ATEN HDMI KVM Keyboard: device is a keyboard
[   269.471] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/event3)
[   269.471] (**) ATEN HDMI KVM: Applying InputClass "libinput pointer catchall"
[   269.471] (II) Using input driver 'libinput' for 'ATEN HDMI KVM'
[   269.471] (**) ATEN HDMI KVM: always reports core events
[   269.471] (**) Option "Device" "/dev/input/event3"
[   269.527] (II) event3  - ATEN HDMI KVM: is tagged by udev as: Mouse
[   269.528] (II) event3  - ATEN HDMI KVM: device is a pointer
[   269.528] (II) event3  - ATEN HDMI KVM: device removed
[   269.558] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.3/0003:0557:222E.0004/input/input3/event3"
[   269.558] (II) XINPUT: Adding extended input device "ATEN HDMI KVM" (type: MOUSE, id 9)
[   269.558] (**) Option "AccelerationScheme" "none"
[   269.558] (**) ATEN HDMI KVM: (accel) selected scheme none/0
[   269.558] (**) ATEN HDMI KVM: (accel) acceleration factor: 2.000
[   269.558] (**) ATEN HDMI KVM: (accel) acceleration threshold: 4
[   269.614] (II) event3  - ATEN HDMI KVM: is tagged by udev as: Mouse
[   269.615] (II) event3  - ATEN HDMI KVM: device is a pointer
[   269.618] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/mouse1)
[   269.618] (II) No input driver specified, ignoring this device.
[   269.618] (II) This device may have been added with another device file.
[   269.632] (**) ATEN HDMI KVM Keyboard: Applying InputClass "libinput keyboard catchall"
[   269.632] (II) Using input driver 'libinput' for 'ATEN HDMI KVM Keyboard'
[   269.632] (**) ATEN HDMI KVM Keyboard: always reports core events
[   269.632] (**) Option "Device" "/dev/input/event2"
[   269.632] (II) libinput: ATEN HDMI KVM Keyboard: is a virtual subdevice
[   269.632] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.2/0003:0557:222E.0003/input/input2/event2"
[   269.632] (II) XINPUT: Adding extended input device "ATEN HDMI KVM Keyboard" (type: KEYBOARD, id 10)
[   269.632] (**) Option "xkb_model" "pc105"
[   269.632] (**) Option "xkb_layout" "us"
[   291.642] (II) event0  - ATEN HDMI KVM: device removed
[   291.653] (II) event1  - ATEN HDMI KVM: device removed
[   291.677] (II) event3  - ATEN HDMI KVM: device removed
[   291.693] (II) event2  - ATEN HDMI KVM Keyboard: device removed
[   291.699] (II) AIGLX: Suspending AIGLX clients for VT switch
[   302.757] (II) UnloadModule: "libinput"
[   302.759] (II) UnloadModule: "libinput"
[   302.770] (II) Server terminated successfully (0). Closing log file.
Please, do you have any idea how to enable both monitors ? Of course, I can use fbdev on both, but it I don´t want. Yet ;-)
Re: Dual gfx cards: DRM + FBDEV
sailorMH wrote: Wed Jun 17, 2026 7:05 pm On my X1000 I had Southern Island card HD6970 for AmigaOS and FirePro V7900 ( TeraScale 3, Cayman ) for linux. Now with two monitors connected I tried to connect both my cards. Of course, HD6970 has no acceleration under linux so I made this xorg.conf:
It has hardware 3D acceleration.
See Radeon HD6970 (Cayman XT)
sailorMH
Post by sailorMH »
xeno74 wrote: Thu Jun 18, 2026 5:42 am
Oh sorry, my mistake. I copy bad gfx card name. The one I have for AmigaOS is HD 7970 Southern Island, CGN 1.
I will correct it above
sailorMH
Post by sailorMH »
... deleted, double post
Maybe libglamor is the problem.
Please prevent the libglamor module from loading.
sudo mv /usr/lib/xorg/modules/libglamoregl.so /usr/lib/xorg/modules/libglamoregl.so.bak
sailorMH
Post by sailorMH »
xeno74 wrote: Thu Jun 18, 2026 8:17 am
Thank you very much, I will try that.
But if I will not load glamoregl, I lost also 2D acceleration on FirePro card - isn´t it?
sailorMH
Post by sailorMH »
I will try one more setting, there is also:
and it is probably enabled by default - I will try set it to "false" with HD7970 card
sailorMH wrote: Thu Jun 18, 2026 9:09 am But if I will not load glamoregl, I lost also 2D acceleration on FirePro card - isn´t it?
Maybe you lost 2D acceleration … but the alternative EXA will load if glamor doesn’t load and then you have 2D acceleration with EXA.
Please look in the log after renaming libglamoregl.so. EXA should work now.
[   551.684] (II) Loading sub module "glamoregl"
[   551.684] (II) LoadModule: "glamoregl"
[   551.685] (WW) Warning, couldn't open module glamoregl
[   551.685] (EE) RADEON: Failed to load module "glamoregl" (module does not exist, 0)
[   551.685] (EE) RADEON(0): glamor not available
[   551.685] (II) Loading sub module "exa"
[   551.685] (II) LoadModule: "exa"
[   551.685] (II) Loading /usr/lib/xorg/modules/libexa.so
[   551.686] (II) Module exa: vendor="X.Org Foundation"
If EXA doesn’t load:
Section "Device"
    Identifier "Radeon"
    Driver "radeon"
    Option "AccelMethod" "EXA"
EndSection
In my point of view, you don’t need the Option "AccelMethod" "EXA" because it loads automatically if glamor doesn’t load.
sailorMH
Post by sailorMH »
@xeno74
Thanks for tip. Unfortunatelly no success without glamore. The same issue.
I made another tests: fbdev on both gfx cards and fbdev on single card ( FirePro, where radeon works fine )
xorg.conf for one gfx ( for two it was uncommented):
#	Screen      1  "Screen1" RightOf "Screen0"
EndSection
Section "Files"
EndSection
Section "Module"
	Load  "glx"
EndSection
	Driver      "kbd"
EndSection
	Identifier  "Mouse0"
	Driver      "mouse"
EndSection
Section "Monitor"
EndSection
#Section "Monitor"
#	Identifier   "Monitor1"
#	VendorName   "Monitor Vendor"
#	ModelName    "Monitor Model"
#EndSection
Section "Device"
	Identifier  "Card0"
	Driver      "fbdev"
	BusID       "PCI:1:0:0"
EndSection
#Section "Device"
#	Identifier  "Card1"
#	Driver      "fbdev"
#	BusID       "PCI:3:0:0"
#EndSection
Section "Screen"
	Device     "Card0"
	Monitor    "Monitor0"
		Viewport   0 0
		Depth     1
	EndSubSection
		Viewport   0 0
		Depth     4
	EndSubSection
		Viewport   0 0
		Depth     8
	EndSubSection
		Viewport   0 0
		Depth     15
	EndSubSection
		Viewport   0 0
		Depth     16
	EndSubSection
		Viewport   0 0
		Depth     24
	EndSubSection
EndSection
#Section "Screen"
#	Identifier "Screen1"
#	Device     "Card1"
#	Monitor    "Monitor1"
#	SubSection "Display"
#		Viewport   0 0
#		Depth     1
#	EndSubSection
#		Viewport   0 0
#		Depth     4
#	EndSubSection
#		Viewport   0 0
#		Depth     8
#	EndSubSection
#		Viewport   0 0
#		Depth     15
#	EndSubSection
#		Viewport   0 0
#		Depth     16
#	EndSubSection
#		Viewport   0 0
#		Depth     24
#	EndSubSection
#EndSection
Two gfx: both black screen
One gfx: one screen black and second off ( no signal )
It looks like fbdev problem or misconfiguration.
Here are log for 1 gfx:
[   445.403]
[   445.427] Current Operating System: Linux amigaone 6.12.76-powerpc64-smp #1 SMP Sat Mar  7 05:21:52 UTC 2026 ppc64
[   445.428] Kernel command line: root=/dev/sdb5 rootdelay=5
[   445.446] xorg-server 2:21.1.7-3 (https://www.debian.org/support)
[   445.455] Current version of pixman: 0.42.2
[   445.474] 	Before reporting problems, check http://wiki.x.org
[   445.474] Markers: (--) probed, (**) from config file, (==) default setting,
[   445.517] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun 18 17:00:40 2026
[   445.528] (++) Using config file: "./xorg.conf.new-fbdev"
[   445.540] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   445.551] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   445.552] (==) ServerLayout "X.org Configured"
[   445.552] (**) |-->Screen "Screen0" (0)
[   445.552] (**) |   |-->Monitor "Monitor0"
[   445.553] (**) |   |-->Device "Card0"
[   445.553] (**) |   |-->GPUDevice "Card0"
[   445.553] (**) |-->Input Device "Mouse0"
[   445.553] (**) |-->Input Device "Keyboard0"
[   445.553] (==) Automatically adding devices
[   445.553] (==) Automatically enabling devices
[   445.553] (==) Automatically adding GPU devices
[   445.553] (==) Automatically binding GPU devices
[   445.553] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   445.553] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[   445.553] 	Entry deleted from font path.
[   445.554] 	Entry deleted from font path.
[   445.554] (**) FontPath set to:
	built-ins,
	built-ins
[   445.554] (**) ModulePath set to "/usr/lib/xorg/modules"
[   445.554] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[   445.554] (WW) Disabling Mouse0
[   445.554] (WW) Disabling Keyboard0
[   445.554] (II) Loader magic: 0x13c222d88
[   445.554] (II) Module ABI versions:
[   445.554] 	X.Org ANSI C Emulation: 0.4
[   445.554] 	X.Org Video Driver: 25.2
[   445.554] 	X.Org XInput driver : 24.4
[   445.554] 	X.Org Server Extension : 10.0
[   445.556] (--) using VT number 2
[   445.556] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   445.560] (II) xfree86: Adding drm device (/dev/dri/card0)
[   445.560] (II) Platform probe for /sys/devices/pci0000:00/0000:00:10.0/0000:01:00.0/drm/card0
[   445.562] (II) xfree86: Adding drm device (/dev/dri/card1)
[   445.562] (II) Platform probe for /sys/devices/pci0000:00/0000:00:10.2/0000:03:00.0/drm/card1
[   445.577] (!!) More than one possible primary device found
[   445.577] (--) PCI: (1@0:0:0) 1002:6704:1002:0b00 rev 0, Mem @ 0x90000000/268435456, 0xa0020000/131072, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[   445.577] (--) PCI: (3@0:0:0) 1002:6798:1682:3212 rev 0, Mem @ 0xb0000000/268435456, 0xc0000000/262144, I/O @ 0x00003000/256, BIOS @ 0x????????/131072
[   445.577] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[   445.577] (II) LoadModule: "glx"
[   445.577] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   445.581] (II) Module glx: vendor="X.Org Foundation"
[   445.581] 	compiled for 1.21.1.7, module version = 1.0.0
[   445.581] 	ABI class: X.Org Server Extension, version 10.0
[   445.581] (II) LoadModule: "radeon"
[   445.581] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[   445.583] (II) Module radeon: vendor="X.Org Foundation"
[   445.583] 	compiled for 1.21.1.3, module version = 19.1.0
[   445.583] 	Module class: X.Org Video Driver
[   445.583] 	ABI class: X.Org Video Driver, version 25.2
[   445.583] (II) LoadModule: "fbdev"
[   445.583] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[   445.583] (II) Module fbdev: vendor="X.Org Foundation"
[   445.583] 	compiled for 1.21.1.3, module version = 0.5.0
[   445.583] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
[   445.588] (II) FBDEV: driver for framebuffer: fbdev
[   445.690] (II) [KMS] Kernel modesetting enabled.
[   445.690] (WW) Falling back to old probe method for fbdev
[   445.690] (II) Loading sub module "fbdevhw"
[   445.690] (II) LoadModule: "fbdevhw"
[   445.690] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[   445.690] (II) Module fbdevhw: vendor="X.Org Foundation"
[   445.690] 	compiled for 1.21.1.7, module version = 0.0.2
[   445.690] 	ABI class: X.Org Video Driver, version 25.2
[   445.691] (II) [KMS] Kernel modesetting enabled.
[   445.691] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[   445.691] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[   445.691] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[   445.691] (==) RADEON(0): Default visual is TrueColor
[   445.691] (**) RADEON(0): Option "Accel" "True"
[   445.691] (==) RADEON(0): RGB weight 888
[   445.691] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[   445.691] (--) RADEON(0): Chipset: "CAYMAN" (ChipID = 0x6704)
[   445.691] (II) Loading sub module "fb"
[   445.691] (II) LoadModule: "fb"
[   445.691] (II) Module "fb" already built-in
[   445.691] (II) Loading sub module "dri2"
[   445.691] (II) LoadModule: "dri2"
[   445.691] (II) Module "dri2" already built-in
[   445.816] (II) Loading sub module "glamoregl"
[   445.816] (II) LoadModule: "glamoregl"
[   445.817] (WW) Warning, couldn't open module glamoregl
[   445.817] (EE) RADEON: Failed to load module "glamoregl" (module does not exist, 0)
[   445.817] (EE) RADEON(0): glamor not available
[   445.817] (II) Loading sub module "exa"
[   445.817] (II) LoadModule: "exa"
[   445.817] (II) Loading /usr/lib/xorg/modules/libexa.so
[   445.817] (II) Module exa: vendor="X.Org Foundation"
[   445.817] 	compiled for 1.21.1.7, module version = 2.6.0
[   445.817] 	ABI class: X.Org Video Driver, version 25.2
[   445.817] (II) RADEON(0): KMS Color Tiling: enabled
[   445.817] (II) RADEON(0): KMS Color Tiling 2D: enabled
[   445.817] (==) RADEON(0): TearFree property default: auto
[   445.817] (II) RADEON(0): KMS Pageflipping: enabled
[   445.817] (II) RADEON(0): SwapBuffers wait for vsync: enabled
[   445.838] (II) RADEON(0): Output DisplayPort-0 using monitor section Monitor0
[   445.855] (II) RADEON(0): Output DisplayPort-1 has no monitor section
[   445.876] (II) RADEON(0): Output DisplayPort-2 has no monitor section
[   445.898] (II) RADEON(0): Output DisplayPort-3 has no monitor section
[   445.919] (II) RADEON(0): EDID for output DisplayPort-0
[   445.935] (II) RADEON(0): EDID for output DisplayPort-1
[   445.935] (II) RADEON(0): Manufacturer: BNQ  Model: 7f11  Serial#: 21573
[   445.935] (II) RADEON(0): Year: 2013  Week: 3
[   445.935] (II) RADEON(0): EDID Version: 1.3
[   445.935] (II) RADEON(0): Digital Display Input
[   445.935] (II) RADEON(0): Max Image Size [cm]: horiz.: 53  vert.: 30
[   445.935] (II) RADEON(0): Gamma: 2.20
[   445.935] (II) RADEON(0): DPMS capabilities: Off
[   445.935] (II) RADEON(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[   445.935] (II) RADEON(0): Default color space is primary color space
[   445.935] (II) RADEON(0): First detailed timing is preferred mode
[   445.935] (II) RADEON(0): redX: 0.649 redY: 0.328   greenX: 0.330 greenY: 0.621
[   445.935] (II) RADEON(0): blueX: 0.150 blueY: 0.053   whiteX: 0.312 whiteY: 0.328
[   445.935] (II) RADEON(0): Supported established timings:
[   445.935] (II) RADEON(0): 720x400@70Hz
[   445.935] (II) RADEON(0): 640x480@60Hz
[   445.935] (II) RADEON(0): 640x480@75Hz
[   445.935] (II) RADEON(0): 800x600@60Hz
[   445.935] (II) RADEON(0): 800x600@75Hz
[   445.935] (II) RADEON(0): 832x624@75Hz
[   445.935] (II) RADEON(0): 1024x768@60Hz
[   445.935] (II) RADEON(0): 1024x768@75Hz
[   445.935] (II) RADEON(0): 1280x1024@75Hz
[   445.935] (II) RADEON(0): 1152x864@75Hz
[   445.935] (II) RADEON(0): Manufacturer's mask: 0
[   445.935] (II) RADEON(0): Supported standard timings:
[   445.935] (II) RADEON(0): #0: hsize: 640  vsize 480  refresh: 100  vid: 26673
[   445.935] (II) RADEON(0): #1: hsize: 640  vsize 480  refresh: 120  vid: 31793
[   445.936] (II) RADEON(0): #2: hsize: 800  vsize 600  refresh: 100  vid: 26693
[   445.936] (II) RADEON(0): #3: hsize: 800  vsize 600  refresh: 120  vid: 31813
[   445.936] (II) RADEON(0): #4: hsize: 1024  vsize 768  refresh: 100  vid: 26721
[   445.936] (II) RADEON(0): #5: hsize: 1024  vsize 768  refresh: 120  vid: 31841
[   445.936] (II) RADEON(0): #6: hsize: 1440  vsize 900  refresh: 120  vid: 15509
[   445.936] (II) RADEON(0): #7: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[   445.936] (II) RADEON(0): Supported detailed timing:
[   445.936] (II) RADEON(0): clock: 148.5 MHz   Image Size:  531 x 298 mm
[   445.936] (II) RADEON(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[   445.936] (II) RADEON(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[   445.936] (II) RADEON(0): Serial No: 51D01957SL0
[   445.936] (II) RADEON(0): Ranges: V min: 24 V max: 120 Hz, H min: 15 H max: 135 kHz, PixClock max 175 MHz
[   445.936] (II) RADEON(0): Monitor name: BenQ XL2411T
[   445.936] (II) RADEON(0): clock: 74.2 MHz   Image Size:  531 x 298 mm
[   445.936] (II) RADEON(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[   445.936] (II) RADEON(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[   445.936] (II) RADEON(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[   445.936] (II) RADEON(0): clock: 27.0 MHz   Image Size:  531 x 298 mm
[   445.936] (II) RADEON(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[   445.936] (II) RADEON(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[   445.936] (II) RADEON(0): Number of EDID sections to follow: 1
[   445.936] (II) RADEON(0): EDID (in hex):
[   445.936] (II) RADEON(0): 	00ffffffffffff0009d1117f45540000
[   445.936] (II) RADEON(0): 	0317010380351e782e48a0a654549f26
[   445.936] (II) RADEON(0): 	0d5054a56b803168317c4568457c6168
[   445.936] (II) RADEON(0): 	617c953cd1c0023a801871382d40582c
[   445.936] (II) RADEON(0): 	4500132a2100001e000000ff00353144
[   445.936] (II) RADEON(0): 	3031393537534c300a20000000fd0018
[   445.936] (II) RADEON(0): 	780f8711000a202020202020000000fc
[   445.936] (II) RADEON(0): 	0042656e5120584c32343131540a0152
[   445.936] (II) RADEON(0): 	020323f1509005040302011112131406
[   445.936] (II) RADEON(0): 	0715161f20230907078301000065030c
[   445.936] (II) RADEON(0): 	001200011d8018711c1620582c250013
[   445.936] (II) RADEON(0): 	2a2100009f011d007251d01e206e2855
[   445.936] (II) RADEON(0): 	00132a2100001f8c0ad08a20e02d1010
[   445.936] (II) RADEON(0): 	3e9600132a2100001900000000000000
[   445.936] (II) RADEON(0): 	00000000000000000000000000000000
[   445.936] (II) RADEON(0): 	000000000000000000000000000000f5
[   445.937] (--) RADEON(0): HDMI max TMDS frequency 145000KHz
[   445.937] (II) RADEON(0): Not using mode "1440x900" (bad mode clock/interlace/doublescan)
[   445.937] (II) RADEON(0): Printing probed modes for output DisplayPort-1
[   445.937] (II) RADEON(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[   445.937] (II) RADEON(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   445.937] (II) RADEON(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[   445.937] (II) RADEON(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[   445.937] (II) RADEON(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[   445.937] (II) RADEON(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[   445.937] (II) RADEON(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[   445.937] (II) RADEON(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[   445.937] (II) RADEON(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   445.937] (II) RADEON(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[   445.937] (II) RADEON(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   445.937] (II) RADEON(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[   445.937] (II) RADEON(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   445.937] (II) RADEON(0): Modeline "1024x768"x120.0  115.50  1024 1072 1104 1184  768 771 775 813 +hsync -vsync (97.6 kHz e)
[   445.937] (II) RADEON(0): Modeline "1024x768"x100.0  113.27  1024 1096 1208 1392  768 769 772 814 -hsync +vsync (81.4 kHz)
[   445.937] (II) RADEON(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   445.937] (II) RADEON(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   445.937] (II) RADEON(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   445.937] (II) RADEON(0): Modeline "800x600"x120.0   73.25  800 848 880 960  600 603 607 636 +hsync -vsync (76.3 kHz e)
[   445.937] (II) RADEON(0): Modeline "800x600"x100.0   68.17  800 848 936 1072  600 601 604 636 -hsync +vsync (63.6 kHz)
[   445.937] (II) RADEON(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   445.937] (II) RADEON(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   445.937] (II) RADEON(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[   445.937] (II) RADEON(0): Modeline "720x576i"x50.0   13.50  720 732 795 864  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[   445.937] (II) RADEON(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   445.937] (II) RADEON(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   445.937] (II) RADEON(0): Modeline "720x480i"x60.0   13.51  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[   445.937] (II) RADEON(0): Modeline "720x480i"x59.9   13.50  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[   445.937] (II) RADEON(0): Modeline "640x480"x120.0   52.40  640 680 744 848  480 481 484 515 -hsync +vsync (61.8 kHz)
[   445.937] (II) RADEON(0): Modeline "640x480"x100.0   43.16  640 680 744 848  480 481 484 509 -hsync +vsync (50.9 kHz)
[   445.937] (II) RADEON(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   445.937] (II) RADEON(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   445.937] (II) RADEON(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   445.938] (II) RADEON(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   445.960] (II) RADEON(0): EDID for output DisplayPort-2
[   445.982] (II) RADEON(0): EDID for output DisplayPort-3
[   445.982] (II) RADEON(0): Output DisplayPort-0 disconnected
[   445.982] (II) RADEON(0): Output DisplayPort-1 connected
[   445.982] (II) RADEON(0): Output DisplayPort-2 disconnected
[   445.982] (II) RADEON(0): Output DisplayPort-3 disconnected
[   445.982] (II) RADEON(0): Using exact sizes for initial modes
[   445.982] (II) RADEON(0): Output DisplayPort-1 using initial mode 1920x1080 +0+0
[   445.982] (II) RADEON(0): mem size init: gart size :3fdce000 vram size: s:80000000 visible:f4b4000
[   445.982] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
[   445.982] (==) RADEON(0): DPI set to (96, 96)
[   445.982] (==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
[   445.982] (II) Loading sub module "ramdac"
[   445.982] (II) LoadModule: "ramdac"
[   445.982] (II) Module "ramdac" already built-in
[   445.983] (==) RADEON(G0): Depth 24, (--) framebuffer bpp 32
[   445.983] (II) RADEON(G0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[   445.983] (==) RADEON(G0): Default visual is TrueColor
[   445.983] (==) RADEON(G0): RGB weight 888
[   445.983] (II) RADEON(G0): Using 8 bits per RGB (8 bit DAC)
[   445.983] (--) RADEON(G0): Chipset: "TAHITI" (ChipID = 0x6798)
[   445.983] (II) Loading sub module "fb"
[   445.983] (II) LoadModule: "fb"
[   445.983] (II) Module "fb" already built-in
[   445.983] (II) Loading sub module "dri2"
[   445.983] (II) LoadModule: "dri2"
[   445.983] (II) Module "dri2" already built-in
[   446.019] (II) Loading sub module "glamoregl"
[   446.019] (II) LoadModule: "glamoregl"
[   446.019] (WW) Warning, couldn't open module glamoregl
[   446.019] (EE) RADEON: Failed to load module "glamoregl" (module does not exist, 0)
[   446.020] (EE) RADEON(G0): glamor not available
[   446.020] (II) Loading sub module "shadow"
[   446.020] (II) LoadModule: "shadow"
[   446.020] (II) Loading /usr/lib/xorg/modules/libshadow.so
[   446.020] (II) Module shadow: vendor="X.Org Foundation"
[   446.020] 	compiled for 1.21.1.7, module version = 1.1.0
[   446.020] 	ABI class: X.Org ANSI C Emulation, version 0.4
[   446.020] (II) RADEON(G0): KMS Color Tiling: disabled
[   446.020] (II) RADEON(G0): KMS Color Tiling 2D: disabled
[   446.041] (II) RADEON(G0): Output DisplayPort-1-4 using monitor section Monitor0
[   446.062] (II) RADEON(G0): Output DisplayPort-1-5 has no monitor section
[   446.123] (II) RADEON(G0): Output HDMI-1-0 has no monitor section
[   446.124] (II) RADEON(G0): Output DVI-1-0 has no monitor section
[   446.131] (II) RADEON(G0): Output DVI-1-1 has no monitor section
[   446.152] (II) RADEON(G0): EDID for output DisplayPort-1-4
[   446.173] (II) RADEON(G0): EDID for output DisplayPort-1-5
[   446.233] (II) RADEON(G0): EDID for output HDMI-1-0
[   446.233] (II) RADEON(G0): Manufacturer: PHL  Model: 946  Serial#: 62885
[   446.234] (II) RADEON(G0): Year: 2025  Week: 43
[   446.234] (II) RADEON(G0): EDID Version: 1.3
[   446.234] (II) RADEON(G0): Digital Display Input
[   446.234] (II) RADEON(G0): Max Image Size [cm]: horiz.: 60  vert.: 34
[   446.234] (II) RADEON(G0): Gamma: 2.20
[   446.234] (II) RADEON(G0): DPMS capabilities: Off
[   446.234] (II) RADEON(G0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[   446.234] (II) RADEON(G0): First detailed timing is preferred mode
[   446.234] (II) RADEON(G0): redX: 0.667 redY: 0.313   greenX: 0.290 greenY: 0.655
[   446.234] (II) RADEON(G0): blueX: 0.152 blueY: 0.047   whiteX: 0.313 whiteY: 0.329
[   446.234] (II) RADEON(G0): Supported established timings:
[   446.234] (II) RADEON(G0): 720x400@70Hz
[   446.234] (II) RADEON(G0): 640x480@60Hz
[   446.234] (II) RADEON(G0): 640x480@67Hz
[   446.234] (II) RADEON(G0): 640x480@72Hz
[   446.234] (II) RADEON(G0): 640x480@75Hz
[   446.234] (II) RADEON(G0): 800x600@56Hz
[   446.234] (II) RADEON(G0): 800x600@60Hz
[   446.234] (II) RADEON(G0): 800x600@72Hz
[   446.234] (II) RADEON(G0): 800x600@75Hz
[   446.234] (II) RADEON(G0): 832x624@75Hz
[   446.234] (II) RADEON(G0): 1024x768@60Hz
[   446.234] (II) RADEON(G0): 1024x768@70Hz
[   446.234] (II) RADEON(G0): 1024x768@75Hz
[   446.234] (II) RADEON(G0): 1280x1024@75Hz
[   446.234] (II) RADEON(G0): Manufacturer's mask: 0
[   446.234] (II) RADEON(G0): Supported standard timings:
[   446.234] (II) RADEON(G0): #0: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[   446.234] (II) RADEON(G0): #1: hsize: 1680  vsize 1050  refresh: 60  vid: 179
[   446.234] (II) RADEON(G0): #2: hsize: 1440  vsize 900  refresh: 60  vid: 149
[   446.234] (II) RADEON(G0): #3: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[   446.234] (II) RADEON(G0): #4: hsize: 1280  vsize 960  refresh: 60  vid: 16513
[   446.234] (II) RADEON(G0): #5: hsize: 1280  vsize 720  refresh: 60  vid: 49281
[   446.234] (II) RADEON(G0): Supported detailed timing:
[   446.234] (II) RADEON(G0): clock: 241.5 MHz   Image Size:  597 x 336 mm
[   446.234] (II) RADEON(G0): h_active: 2560  h_sync: 2608  h_sync_end 2640 h_blank_end 2720 h_border: 0
[   446.234] (II) RADEON(G0): v_active: 1440  v_sync: 1443  v_sync_end 1448 v_blanking: 1481 v_border: 0
[   446.234] (II) RADEON(G0): Serial No: UK02543062885
[   446.234] (II) RADEON(G0): Monitor name: PHL 275B1
[   446.234] (II) RADEON(G0): Ranges: V min: 48 V max: 75 Hz, H min: 30 H max: 114 kHz, PixClock max 305 MHz
[   446.234] (II) RADEON(G0): clock: 296.0 MHz   Image Size:  597 x 336 mm
[   446.234] (II) RADEON(G0): h_active: 2560  h_sync: 2568  h_sync_end 2600 h_blank_end 2666 h_border: 0
[   446.234] (II) RADEON(G0): clock: 174.5 MHz   Image Size:  597 x 336 mm
[   446.234] (II) RADEON(G0): h_active: 1920  h_sync: 1968  h_sync_end 2000 h_blank_end 2080 h_border: 0
[   446.234] (II) RADEON(G0): v_active: 1080  v_sync: 1083  v_sync_end 1088 v_blanking: 1119 v_border: 0
[   446.234] (II) RADEON(G0): clock: 148.5 MHz   Image Size:  597 x 336 mm
[   446.234] (II) RADEON(G0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[   446.234] (II) RADEON(G0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[   446.235] (II) RADEON(G0): Number of EDID sections to follow: 1
[   446.235] (II) RADEON(G0): EDID (in hex):
[   446.235] (II) RADEON(G0): 	00ffffffffffff00410c4609a5f50000
[   446.235] (II) RADEON(G0): 	2b230103803c22782ad705aa504aa727
[   446.235] (II) RADEON(G0): 	0c5054bfef00d1c0b300950081808140
[   446.235] (II) RADEON(G0): 	81c001010101565e00a0a0a029503020
[   446.235] (II) RADEON(G0): 	350055502100001e000000ff00554b30
[   446.235] (II) RADEON(G0): 	32353433303632383835000000fc0050
[   446.235] (II) RADEON(G0): 	484c2032373542310a202020000000fd
[   446.235] (II) RADEON(G0): 	00304b1e721e000a2020202020200116
[   446.235] (II) RADEON(G0): 	02031ef14b101f051404130312021101
[   446.235] (II) RADEON(G0): 	230907078301000065030c001300a073
[   446.235] (II) RADEON(G0): 	006aa0a029500820350055502100001a
[   446.235] (II) RADEON(G0): 	2a4480a0703827403020350055502100
[   446.235] (II) RADEON(G0): 	001a023a801871382d40582c45005550
[   446.235] (II) RADEON(G0): 	2100001e000000000000000000000000
[   446.235] (II) RADEON(G0): 	00000000000000000000000000000000
[   446.235] (II) RADEON(G0): 	000000000000000000000000000000c8
[   446.235] (--) RADEON(G0): HDMI max TMDS frequency 575000KHz
[   446.235] (II) RADEON(G0): Printing probed modes for output HDMI-1-0
[   446.235] (II) RADEON(G0): Modeline "2560x1440"x60.0  241.50  2560 2608 2640 2720  1440 1443 1448 1481 +hsync +vsync (88.8 kHz eP)
[   446.235] (II) RADEON(G0): Modeline "2560x1440"x75.0  296.00  2560 2568 2600 2666  1440 1443 1448 1481 +hsync -vsync (111.0 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1920x1080"x75.0  174.50  1920 1968 2000 2080  1080 1083 1088 1119 +hsync -vsync (83.9 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1680x1050"x59.9  119.00  1680 1728 1760 1840  1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1440x900"x59.9   88.75  1440 1488 1520 1600  900 903 909 926 +hsync -vsync (55.5 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1280x960"x60.0  108.00  1280 1376 1488 1800  960 961 964 1000 +hsync +vsync (60.0 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   446.235] (II) RADEON(G0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[   446.236] (II) RADEON(G0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[   446.236] (II) RADEON(G0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[   446.236] (II) RADEON(G0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[   446.236] (II) RADEON(G0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[   446.236] (II) RADEON(G0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[   446.236] (II) RADEON(G0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[   446.236] (II) RADEON(G0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[   446.236] (II) RADEON(G0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[   446.236] (II) RADEON(G0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[   446.236] (II) RADEON(G0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[   446.236] (II) RADEON(G0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   446.236] (II) RADEON(G0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[   446.236] (II) RADEON(G0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[   446.236] (II) RADEON(G0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[   446.236] (II) RADEON(G0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[   446.236] (II) RADEON(G0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   446.236] (II) RADEON(G0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[   446.236] (II) RADEON(G0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[   446.237] (II) RADEON(G0): EDID for output DVI-1-0
[   446.244] (II) RADEON(G0): EDID for output DVI-1-1
[   446.244] (II) RADEON(G0): mem size init: gart size :3fbcc000 vram size: s:c0000000 visible:ee18000
[   446.244] (II) RADEON(G0): EXA: Driver will allow EXA pixmaps in VRAM
[   446.244] (==) RADEON(G0): DPI set to (96, 96)
[   446.244] (==) RADEON(G0): Using gamma correction (1.0, 1.0, 1.0)
[   446.244] (II) Loading sub module "ramdac"
[   446.244] (II) LoadModule: "ramdac"
[   446.244] (II) Module "ramdac" already built-in
[   446.244] (II) UnloadModule: "fbdev"
[   446.244] (II) Unloading fbdev
[   446.244] (II) UnloadSubModule: "fbdevhw"
[   446.244] (II) Unloading fbdevhw
[   446.245] (II) RADEON(0): [DRI2] Setup complete
[   446.245] (II) RADEON(0): [DRI2]   DRI driver: r600
[   446.245] (II) RADEON(0): [DRI2]   VDPAU driver: r600
[   446.245] (II) RADEON(0): Front buffer size: 8100K
[   446.245] (II) RADEON(0): VRAM usage limit set to 218142K
[   446.245] (==) RADEON(0): DRI3 disabled
[   446.245] (==) RADEON(0): Backing store enabled
[   446.245] (II) RADEON(0): Direct rendering enabled
[   446.245] (II) EXA(0): Driver allocated offscreen pixmaps
[   446.246] (II) EXA(0): Driver registered support for the following operations:
[   446.246] (II)         Solid
[   446.246] (II)         Copy
[   446.246] (II)         Composite (RENDER acceleration)
[   446.246] (II)         UploadToScreen
[   446.246] (II)         DownloadFromScreen
[   446.246] (II) RADEON(0): Acceleration enabled
[   446.246] (==) RADEON(0): DPMS enabled
[   446.246] (==) RADEON(0): Silken mouse enabled
[   446.246] (II) RADEON(0): Set up textured video
[   446.246] (II) RADEON(0): [XvMC] Associated with Radeon Textured Video.
[   446.246] (II) RADEON(0): [XvMC] Extension initialized.
[   446.258] (II) RADEON(G0): Front buffer size: 3072K
[   446.258] (II) RADEON(G0): VRAM usage limit set to 216576K
[   446.258] (==) RADEON(G0): Backing store enabled
[   446.258] (WW) RADEON(G0): Direct rendering disabled
[   446.258] (II) RADEON(G0): Acceleration disabled
[   446.258] (==) RADEON(G0): DPMS enabled
[   446.258] (==) RADEON(G0): Silken mouse enabled
[   446.270] (II) Initializing extension Generic Event Extension
[   446.270] (II) Initializing extension SHAPE
[   446.271] (II) Initializing extension MIT-SHM
[   446.272] (II) Initializing extension XInputExtension
[   446.272] (II) Initializing extension XTEST
[   446.273] (II) Initializing extension BIG-REQUESTS
[   446.274] (II) Initializing extension SYNC
[   446.275] (II) Initializing extension XKEYBOARD
[   446.275] (II) Initializing extension XC-MISC
[   446.276] (II) Initializing extension SECURITY
[   446.277] (II) Initializing extension XFIXES
[   446.277] (II) Initializing extension RENDER
[   446.278] (II) Initializing extension RANDR
[   446.279] (II) Initializing extension COMPOSITE
[   446.280] (II) Initializing extension DAMAGE
[   446.281] (II) Initializing extension MIT-SCREEN-SAVER
[   446.281] (II) Initializing extension DOUBLE-BUFFER
[   446.282] (II) Initializing extension RECORD
[   446.283] (II) Initializing extension DPMS
[   446.283] (II) Initializing extension Present
[   446.284] (II) Initializing extension DRI3
[   446.284] (II) Initializing extension X-Resource
[   446.285] (II) Initializing extension XVideo
[   446.285] (II) Initializing extension XVideo-MotionCompensation
[   446.286] (II) Initializing extension SELinux
[   446.286] (II) SELinux: Disabled on system
[   446.286] (II) Initializing extension GLX
[   446.305] (II) AIGLX: Loaded and initialized r600
[   446.305] (II) GLX: Initialized DRI2 GL provider for screen 0
[   446.305] (II) Initializing extension XFree86-VidModeExtension
[   446.306] (II) Initializing extension XFree86-DGA
[   446.307] (II) Initializing extension XFree86-DRI
[   446.307] (II) Initializing extension DRI2
[   446.336] (II) RADEON(0): Setting screen physical size to 508 x 285
[   446.557] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/event0)
[   446.557] (**) ATEN HDMI KVM: Applying InputClass "libinput keyboard catchall"
[   446.557] (II) LoadModule: "libinput"
[   446.557] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[   446.562] (II) Module libinput: vendor="X.Org Foundation"
[   446.563] 	compiled for 1.21.1.3, module version = 1.2.1
[   446.563] 	Module class: X.Org XInput Driver
[   446.563] 	ABI class: X.Org XInput driver, version 24.4
[   446.563] (II) Using input driver 'libinput' for 'ATEN HDMI KVM'
[   446.563] (**) ATEN HDMI KVM: always reports core events
[   446.563] (**) Option "Device" "/dev/input/event0"
[   446.573] (II) event0  - ATEN HDMI KVM: is tagged by udev as: Keyboard
[   446.573] (II) event0  - ATEN HDMI KVM: device is a keyboard
[   446.574] (II) event0  - ATEN HDMI KVM: device removed
[   446.591] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.0/0003:0557:222E.0001/input/input0/event0"
[   446.591] (II) XINPUT: Adding extended input device "ATEN HDMI KVM" (type: KEYBOARD, id 6)
[   446.591] (**) Option "xkb_model" "pc105"
[   446.591] (**) Option "xkb_layout" "us"
[   446.597] (II) event0  - ATEN HDMI KVM: is tagged by udev as: Keyboard
[   446.597] (II) event0  - ATEN HDMI KVM: device is a keyboard
[   446.600] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/event1)
[   446.600] (**) ATEN HDMI KVM: Applying InputClass "libinput pointer catchall"
[   446.600] (II) Using input driver 'libinput' for 'ATEN HDMI KVM'
[   446.600] (**) ATEN HDMI KVM: always reports core events
[   446.600] (**) Option "Device" "/dev/input/event1"
[   446.656] (II) event1  - ATEN HDMI KVM: is tagged by udev as: Mouse
[   446.657] (II) event1  - ATEN HDMI KVM: device is a pointer
[   446.657] (II) event1  - ATEN HDMI KVM: device removed
[   446.682] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.1/0003:0557:222E.0002/input/input1/event1"
[   446.682] (II) XINPUT: Adding extended input device "ATEN HDMI KVM" (type: MOUSE, id 7)
[   446.682] (**) Option "AccelerationScheme" "none"
[   446.682] (**) ATEN HDMI KVM: (accel) selected scheme none/0
[   446.682] (**) ATEN HDMI KVM: (accel) acceleration factor: 2.000
[   446.682] (**) ATEN HDMI KVM: (accel) acceleration threshold: 4
[   446.738] (II) event1  - ATEN HDMI KVM: is tagged by udev as: Mouse
[   446.739] (II) event1  - ATEN HDMI KVM: device is a pointer
[   446.742] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/mouse0)
[   446.742] (II) No input driver specified, ignoring this device.
[   446.742] (II) This device may have been added with another device file.
[   446.745] (II) config/udev: Adding input device ATEN HDMI KVM Keyboard (/dev/input/event2)
[   446.745] (**) ATEN HDMI KVM Keyboard: Applying InputClass "libinput keyboard catchall"
[   446.745] (II) Using input driver 'libinput' for 'ATEN HDMI KVM Keyboard'
[   446.745] (**) ATEN HDMI KVM Keyboard: always reports core events
[   446.745] (**) Option "Device" "/dev/input/event2"
[   446.750] (II) event2  - ATEN HDMI KVM Keyboard: is tagged by udev as: Keyboard
[   446.750] (II) event2  - ATEN HDMI KVM Keyboard: device is a keyboard
[   446.751] (II) event2  - ATEN HDMI KVM Keyboard: device removed
[   446.768] (II) libinput: ATEN HDMI KVM Keyboard: needs a virtual subdevice
[   446.768] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.2/0003:0557:222E.0003/input/input2/event2"
[   446.768] (II) XINPUT: Adding extended input device "ATEN HDMI KVM Keyboard" (type: MOUSE, id 8)
[   446.768] (**) Option "AccelerationScheme" "none"
[   446.768] (**) ATEN HDMI KVM Keyboard: (accel) selected scheme none/0
[   446.768] (**) ATEN HDMI KVM Keyboard: (accel) acceleration factor: 2.000
[   446.768] (**) ATEN HDMI KVM Keyboard: (accel) acceleration threshold: 4
[   446.773] (II) event2  - ATEN HDMI KVM Keyboard: is tagged by udev as: Keyboard
[   446.774] (II) event2  - ATEN HDMI KVM Keyboard: device is a keyboard
[   446.777] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/event3)
[   446.777] (**) ATEN HDMI KVM: Applying InputClass "libinput pointer catchall"
[   446.777] (II) Using input driver 'libinput' for 'ATEN HDMI KVM'
[   446.777] (**) ATEN HDMI KVM: always reports core events
[   446.777] (**) Option "Device" "/dev/input/event3"
[   446.833] (II) event3  - ATEN HDMI KVM: is tagged by udev as: Mouse
[   446.834] (II) event3  - ATEN HDMI KVM: device is a pointer
[   446.834] (II) event3  - ATEN HDMI KVM: device removed
[   446.851] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.3/0003:0557:222E.0004/input/input3/event3"
[   446.851] (II) XINPUT: Adding extended input device "ATEN HDMI KVM" (type: MOUSE, id 9)
[   446.851] (**) Option "AccelerationScheme" "none"
[   446.851] (**) ATEN HDMI KVM: (accel) selected scheme none/0
[   446.851] (**) ATEN HDMI KVM: (accel) acceleration factor: 2.000
[   446.851] (**) ATEN HDMI KVM: (accel) acceleration threshold: 4
[   446.907] (II) event3  - ATEN HDMI KVM: is tagged by udev as: Mouse
[   446.908] (II) event3  - ATEN HDMI KVM: device is a pointer
[   446.911] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/mouse1)
[   446.911] (II) No input driver specified, ignoring this device.
[   446.911] (II) This device may have been added with another device file.
[   446.925] (**) ATEN HDMI KVM Keyboard: Applying InputClass "libinput keyboard catchall"
[   446.925] (II) Using input driver 'libinput' for 'ATEN HDMI KVM Keyboard'
[   446.925] (**) ATEN HDMI KVM Keyboard: always reports core events
[   446.925] (**) Option "Device" "/dev/input/event2"
[   446.925] (II) libinput: ATEN HDMI KVM Keyboard: is a virtual subdevice
[   446.925] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.2/0003:0557:222E.0003/input/input2/event2"
[   446.925] (II) XINPUT: Adding extended input device "ATEN HDMI KVM Keyboard" (type: KEYBOARD, id 10)
[   446.925] (**) Option "xkb_model" "pc105"
[   446.925] (**) Option "xkb_layout" "us"
[   472.529] (II) event0  - ATEN HDMI KVM: device removed
[   472.539] (II) event1  - ATEN HDMI KVM: device removed
[   472.553] (II) event3  - ATEN HDMI KVM: device removed
[   472.571] (II) event2  - ATEN HDMI KVM Keyboard: device removed
[   472.577] (II) AIGLX: Suspending AIGLX clients for VT switch
[   480.652] (II) UnloadModule: "libinput"
[   480.654] (II) UnloadModule: "libinput"
[   480.659] (II) Server terminated successfully (0). Closing log file.
sailorMH
Post by sailorMH »
And here for 2 gfx:
[    82.941]
X.Org X Server 1.21.1.7
X Protocol Version 11, Revision 0
[    82.942] Current Operating System: Linux amigaone 6.12.76-powerpc64-smp #1 SMP Sat Mar  7 05:21:52 UTC 2026 ppc64
[    82.942] Kernel command line: root=/dev/sdb5 rootdelay=5
[    82.943] xorg-server 2:21.1.7-3 (https://www.debian.org/support)
[    82.943] Current version of pixman: 0.42.2
[    82.944] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[    82.944] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    82.946] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun 18 16:54:38 2026
[    82.947] (++) Using config file: "./xorg.conf.new-fbdev"
[    82.947] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    82.948] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    82.956] (==) ServerLayout "X.org Configured"
[    82.956] (**) |-->Screen "Screen0" (0)
[    82.956] (**) |   |-->Monitor "Monitor0"
[    82.956] (**) |   |-->Device "Card0"
[    82.956] (**) |-->Screen "Screen1" (1)
[    82.956] (**) |   |-->Monitor "Monitor1"
[    82.957] (**) |   |-->Device "Card1"
[    82.957] (**) |-->Input Device "Mouse0"
[    82.957] (**) |-->Input Device "Keyboard0"
[    82.957] (==) Automatically adding devices
[    82.957] (==) Automatically enabling devices
[    82.957] (==) Automatically adding GPU devices
[    82.957] (==) Automatically binding GPU devices
[    82.957] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    82.957] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    82.957] 	Entry deleted from font path.
[    82.958] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    82.958] 	Entry deleted from font path.
[    82.958] (**) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/100dpi/:unscaled,
	/usr/share/fonts/X11/75dpi/:unscaled,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins,
	built-ins
[    82.958] (**) ModulePath set to "/usr/lib/xorg/modules"
[    82.958] (WW) Hotplugging is on, devices using drivers 'kbd', 'mouse' or 'vmmouse' will be disabled.
[    82.958] (WW) Disabling Mouse0
[    82.958] (WW) Disabling Keyboard0
[    82.958] (II) Loader magic: 0x12a292d88
[    82.958] (II) Module ABI versions:
[    82.958] 	X.Org ANSI C Emulation: 0.4
[    82.958] 	X.Org Video Driver: 25.2
[    82.958] 	X.Org XInput driver : 24.4
[    82.958] 	X.Org Server Extension : 10.0
[    82.960] (--) using VT number 2
[    82.960] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    82.964] (II) xfree86: Adding drm device (/dev/dri/card0)
[    82.964] (II) Platform probe for /sys/devices/pci0000:00/0000:00:10.0/0000:01:00.0/drm/card0
[    82.966] (II) xfree86: Adding drm device (/dev/dri/card1)
[    82.966] (II) Platform probe for /sys/devices/pci0000:00/0000:00:10.2/0000:03:00.0/drm/card1
[    82.981] (!!) More than one possible primary device found
[    82.981] (--) PCI: (1@0:0:0) 1002:6704:1002:0b00 rev 0, Mem @ 0x90000000/268435456, 0xa0020000/131072, I/O @ 0x00002000/256, BIOS @ 0x????????/131072
[    82.981] (--) PCI: (3@0:0:0) 1002:6798:1682:3212 rev 0, Mem @ 0xb0000000/268435456, 0xc0000000/262144, I/O @ 0x00003000/256, BIOS @ 0x????????/131072
[    82.981] (II) "glx" will be loaded. This was enabled by default and also specified in the config file.
[    82.981] (II) LoadModule: "glx"
[    82.981] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    82.985] (II) Module glx: vendor="X.Org Foundation"
[    82.985] 	compiled for 1.21.1.7, module version = 1.0.0
[    82.985] 	ABI class: X.Org Server Extension, version 10.0
[    82.985] (II) LoadModule: "radeon"
[    82.985] (II) Loading /usr/lib/xorg/modules/drivers/radeon_drv.so
[    82.987] (II) Module radeon: vendor="X.Org Foundation"
[    82.987] 	compiled for 1.21.1.3, module version = 19.1.0
[    82.987] 	Module class: X.Org Video Driver
[    82.987] 	ABI class: X.Org Video Driver, version 25.2
[    82.987] (II) LoadModule: "fbdev"
[    82.987] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[    82.994] (II) Module fbdev: vendor="X.Org Foundation"
[    82.995] 	compiled for 1.21.1.3, module version = 0.5.0
[    82.995] 	Module class: X.Org Video Driver
[    82.995] 	ABI class: X.Org Video Driver, version 25.2
[    82.995] (II) RADEON: Driver for ATI/AMD Radeon chipsets:
	ATI Radeon Mobility X600 (M24), ATI FireMV 2400,
	ATI Radeon Mobility X300 (M24), ATI FireGL M24 GL,
	ATI Radeon X600 (RV380), ATI FireGL V3200 (RV380),
	ATI Radeon IGP320 (A3), ATI Radeon IGP330/340/350 (A4),
	ATI Radeon 9500, ATI Radeon 9600TX, ATI FireGL Z1, ATI Radeon 9800SE,
	ATI Radeon 9800, ATI FireGL X2, ATI Radeon 9600, ATI Radeon 9600SE,
	ATI Radeon 9600XT, ATI FireGL T2, ATI Radeon 9650, ATI FireGL RV360,
	ATI Radeon 7000 IGP (A4+), ATI Radeon 8500 AIW,
	ATI Radeon IGP320M (U1), ATI Radeon IGP330M/340M/350M (U2),
	ATI Radeon Mobility 7000 IGP, ATI Radeon 9000/PRO, ATI Radeon 9000,
	ATI Radeon X800 (R420), ATI Radeon X800PRO (R420),
	ATI Radeon X800SE (R420), ATI FireGL X3 (R420),
	ATI Radeon Mobility 9800 (M18), ATI Radeon X800 SE (R420),
	ATI Radeon X800XT (R420), ATI Radeon X800 VE (R420),
	ATI Radeon X850 (R480), ATI Radeon X850 XT (R480),
	ATI Radeon X850 SE (R480), ATI Radeon X850 PRO (R480),
	ATI Radeon X850 XT PE (R480), ATI Radeon Mobility M7,
	ATI Mobility FireGL 7800 M7, ATI Radeon Mobility M6,
	ATI FireGL Mobility 9000 (M9), ATI Radeon Mobility 9000 (M9),
	ATI Radeon 9700 Pro, ATI Radeon 9700/9500Pro, ATI FireGL X1,
	ATI Radeon 9800PRO, ATI Radeon 9800XT,
	ATI Radeon Mobility 9600/9700 (M10/M11),
	ATI Radeon Mobility 9600 (M10), ATI Radeon Mobility 9600 (M11),
	ATI FireGL Mobility T2 (M10), ATI FireGL Mobility T2e (M11),
	ATI Radeon, ATI FireGL 8700/8800, ATI Radeon 8500, ATI Radeon 9100,
	ATI Radeon 7500, ATI Radeon VE/7000, ATI ES1000,
	ATI Radeon Mobility X300 (M22), ATI Radeon Mobility X600 SE (M24C),
	ATI FireGL M22 GL, ATI Radeon X800 (R423), ATI Radeon X800PRO (R423),
	ATI Radeon X800LE (R423), ATI Radeon X800SE (R423),
	ATI Radeon X800 XTP (R430), ATI Radeon X800 XL (R430),
	ATI Radeon X800 SE (R430), ATI Radeon X800 (R430),
	ATI FireGL V7100 (R423), ATI FireGL V5100 (R423),
	ATI FireGL unknown (R423), ATI Mobility FireGL V5000 (M26),
	ATI Mobility Radeon X700 XL (M26), ATI Mobility Radeon X700 (M26),
	ATI Radeon X550XTX, ATI Radeon 9100 IGP (A5),
	ATI Radeon Mobility 9100 IGP (U3), ATI Radeon XPRESS 200,
	ATI Radeon XPRESS 200M, ATI Radeon 9250, ATI Radeon 9200,
	ATI Radeon 9200SE, ATI FireMV 2200, ATI Radeon X300 (RV370),
	ATI Radeon X600 (RV370), ATI Radeon X550 (RV370),
	ATI FireGL V3100 (RV370), ATI FireMV 2200 PCIE (RV370),
	ATI Radeon Mobility 9200 (M9+), ATI Mobility Radeon X800 XT (M28),
	ATI Mobility FireGL V5100 (M28), ATI Mobility Radeon X800 (M28),
	ATI Radeon X850, ATI unknown Radeon / FireGL (R480),
	ATI Radeon X800XT (R423), ATI FireGL V5000 (RV410),
	ATI Radeon X700 XT (RV410), ATI Radeon X700 PRO (RV410),
	ATI Radeon X700 SE (RV410), ATI Radeon X700 (RV410),
	ATI Radeon X1800, ATI Mobility Radeon X1800 XT,
	ATI Mobility Radeon X1800, ATI Mobility FireGL V7200,
	ATI FireGL V7200, ATI FireGL V5300, ATI Mobility FireGL V7100,
	ATI FireGL V7300, ATI FireGL V7350, ATI Radeon X1600, ATI RV505,
	ATI Radeon X1300/X1550, ATI Radeon X1550, ATI M54-GL,
	ATI Mobility Radeon X1400, ATI Radeon X1550 64-bit,
	ATI Mobility Radeon X1300, ATI Radeon X1300, ATI FireGL V3300,
	ATI FireGL V3350, ATI Mobility Radeon X1450,
	ATI Mobility Radeon X2300, ATI Mobility Radeon X1350,
	ATI FireMV 2250, ATI Radeon X1650, ATI Mobility FireGL V5200,
	ATI Mobility Radeon X1600, ATI Radeon X1300 XT/X1600 Pro,
	ATI FireGL V3400, ATI Mobility FireGL V5250,
	ATI Mobility Radeon X1700, ATI Mobility Radeon X1700 XT,
	ATI FireGL V5200, ATI Radeon X2300HD, ATI Mobility Radeon HD 2300,
	ATI Radeon X1950, ATI Radeon X1900, ATI AMD Stream Processor,
	ATI RV560, ATI Mobility Radeon X1900, ATI Radeon X1950 GT, ATI RV570,
	ATI FireGL V7400, ATI Radeon 9100 PRO IGP,
	ATI Radeon Mobility 9200 IGP, ATI Radeon X1200, ATI RS740,
	ATI RS740M, ATI Radeon HD 2900 XT, ATI Radeon HD 2900 Pro,
	ATI Radeon HD 2900 GT, ATI FireGL V8650, ATI FireGL V8600,
	ATI FireGL V7600, ATI Radeon 4800 Series, ATI Radeon HD 4870 x2,
	ATI Radeon HD 4850 x2, ATI FirePro V8750 (FireGL),
	ATI FirePro V7760 (FireGL), ATI Mobility RADEON HD 4850,
	ATI Mobility RADEON HD 4850 X2, ATI FirePro RV770,
	AMD FireStream 9270, AMD FireStream 9250, ATI FirePro V8700 (FireGL),
	ATI Mobility RADEON HD 4870, ATI Mobility RADEON M98,
	ATI FirePro M7750, ATI M98, ATI Mobility Radeon HD 4650,
	ATI Radeon RV730 (AGP), ATI Mobility Radeon HD 4670,
	ATI FirePro M5750, ATI RV730XT [Radeon HD 4670], ATI RADEON E4600,
	ATI Radeon HD 4600 Series, ATI RV730 PRO [Radeon HD 4650],
	ATI FirePro V7750 (FireGL), ATI FirePro V5700 (FireGL),
	ATI FirePro V3750 (FireGL), ATI Mobility Radeon HD 4830,
	ATI Mobility Radeon HD 4850, ATI FirePro M7740, ATI RV740,
	ATI Radeon HD 4770, ATI Radeon HD 4700 Series, ATI RV610,
	ATI Radeon HD 2400 XT, ATI Radeon HD 2400 Pro,
	ATI Radeon HD 2400 PRO AGP, ATI FireGL V4000, ATI Radeon HD 2350,
	ATI Mobility Radeon HD 2400 XT, ATI Mobility Radeon HD 2400,
	ATI RADEON E2400, ATI FireMV 2260, ATI RV670, ATI Radeon HD3870,
	ATI Mobility Radeon HD 3850, ATI Radeon HD3850,
	ATI Mobility Radeon HD 3850 X2, ATI Mobility Radeon HD 3870,
	ATI Mobility Radeon HD 3870 X2, ATI Radeon HD3870 X2,
	ATI FireGL V7700, ATI Radeon HD3690, AMD Firestream 9170,
	ATI Radeon HD 4550, ATI Radeon RV710, ATI Radeon HD 4350,
	ATI Mobility Radeon 4300 Series, ATI Mobility Radeon 4500 Series,
	ATI FirePro RG220, ATI Mobility Radeon 4330, ATI RV630,
	ATI Mobility Radeon HD 2600, ATI Mobility Radeon HD 2600 XT,
	ATI Radeon HD 2600 XT AGP, ATI Radeon HD 2600 Pro AGP,
	ATI Radeon HD 2600 XT, ATI Radeon HD 2600 Pro, ATI Gemini RV630,
	ATI Gemini Mobility Radeon HD 2600 XT, ATI FireGL V5600,
	ATI FireGL V3600, ATI Radeon HD 2600 LE,
	ATI Mobility FireGL Graphics Processor, ATI Radeon HD 3470,
	ATI Mobility Radeon HD 3430, ATI Mobility Radeon HD 3400 Series,
	ATI Radeon HD 3450, ATI Radeon HD 3430, ATI FirePro V3700,
	ATI FireMV 2450, ATI Radeon HD 3600 Series, ATI Radeon HD 3650 AGP,
	ATI Radeon HD 3600 PRO, ATI Radeon HD 3600 XT,
	ATI Mobility Radeon HD 3650, ATI Mobility Radeon HD 3670,
	ATI Mobility FireGL V5700, ATI Mobility FireGL V5725,
	ATI Radeon HD 3200 Graphics, ATI Radeon 3100 Graphics,
	ATI Radeon HD 3300 Graphics, ATI Radeon 3000 Graphics, SUMO, SUMO2,
	ATI Radeon HD 4200, ATI Radeon 4100, ATI Mobility Radeon HD 4200,
	ATI Mobility Radeon 4100, ATI Radeon HD 4290, ATI Radeon HD 4250,
	AMD Radeon HD 6310 Graphics, AMD Radeon HD 6250 Graphics,
	AMD Radeon HD 6300 Series Graphics,
	AMD Radeon HD 6200 Series Graphics, PALM, CYPRESS,
	ATI FirePro (FireGL) Graphics Adapter, AMD Firestream 9370,
	AMD Firestream 9350, ATI Radeon HD 5800 Series,
	ATI Radeon HD 5900 Series, ATI Mobility Radeon HD 5800 Series,
	ATI Radeon HD 5700 Series, ATI Radeon HD 6700 Series,
	ATI Mobility Radeon HD 5000 Series, ATI Mobility Radeon HD 5570,
	ATI Radeon HD 5670, ATI Radeon HD 5570, ATI Radeon HD 5500 Series,
	REDWOOD, ATI Mobility Radeon Graphics, CEDAR, ATI FirePro 2270,
	ATI Radeon HD 5450, CAYMAN, AMD Radeon HD 6900 Series,
	AMD Radeon HD 6900M Series, Mobility Radeon HD 6000 Series, BARTS,
	AMD Radeon HD 6800 Series, AMD Radeon HD 6700 Series, TURKS, CAICOS,
	ARUBA, TAHITI, PITCAIRN, VERDE, OLAND, HAINAN, BONAIRE, KABINI,
	MULLINS, KAVERI, HAWAII
[    82.999] (II) FBDEV: driver for framebuffer: fbdev
[    83.101] (II) [KMS] Kernel modesetting enabled.
[    83.101] (II) Loading sub module "fbdevhw"
[    83.101] (II) LoadModule: "fbdevhw"
[    83.101] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[    83.111] (II) Module fbdevhw: vendor="X.Org Foundation"
[    83.111] 	compiled for 1.21.1.7, module version = 0.0.2
[    83.111] 	ABI class: X.Org Video Driver, version 25.2
[    83.112] (**) FBDEV(1): claimed PCI slot 3@0:0:0
[    83.112] (II) FBDEV(1): using default device
[    83.112] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    83.112] (==) RADEON(0): Depth 24, (--) framebuffer bpp 32
[    83.112] (II) RADEON(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[    83.112] (==) RADEON(0): Default visual is TrueColor
[    83.112] (**) RADEON(0): Option "Accel" "True"
[    83.112] (==) RADEON(0): RGB weight 888
[    83.112] (II) RADEON(0): Using 8 bits per RGB (8 bit DAC)
[    83.112] (--) RADEON(0): Chipset: "CAYMAN" (ChipID = 0x6704)
[    83.112] (II) Loading sub module "fb"
[    83.112] (II) LoadModule: "fb"
[    83.112] (II) Module "fb" already built-in
[    83.112] (II) Loading sub module "dri2"
[    83.112] (II) LoadModule: "dri2"
[    83.112] (II) Module "dri2" already built-in
[    83.238] (II) Loading sub module "glamoregl"
[    83.238] (II) LoadModule: "glamoregl"
[    83.238] (WW) Warning, couldn't open module glamoregl
[    83.239] (EE) RADEON: Failed to load module "glamoregl" (module does not exist, 0)
[    83.239] (EE) RADEON(0): glamor not available
[    83.239] (II) Loading sub module "exa"
[    83.239] (II) LoadModule: "exa"
[    83.239] (II) Loading /usr/lib/xorg/modules/libexa.so
[    83.239] (II) Module exa: vendor="X.Org Foundation"
[    83.239] 	compiled for 1.21.1.7, module version = 2.6.0
[    83.239] 	ABI class: X.Org Video Driver, version 25.2
[    83.239] (II) RADEON(0): KMS Color Tiling: enabled
[    83.239] (II) RADEON(0): KMS Color Tiling 2D: enabled
[    83.239] (==) RADEON(0): TearFree property default: auto
[    83.239] (II) RADEON(0): KMS Pageflipping: enabled
[    83.239] (II) RADEON(0): SwapBuffers wait for vsync: enabled
[    83.260] (II) RADEON(0): Output DisplayPort-0 using monitor section Monitor0
[    83.276] (II) RADEON(0): Output DisplayPort-1 has no monitor section
[    83.297] (II) RADEON(0): Output DisplayPort-2 has no monitor section
[    83.318] (II) RADEON(0): Output DisplayPort-3 has no monitor section
[    83.339] (II) RADEON(0): EDID for output DisplayPort-0
[    83.355] (II) RADEON(0): EDID for output DisplayPort-1
[    83.355] (II) RADEON(0): Manufacturer: BNQ  Model: 7f11  Serial#: 21573
[    83.355] (II) RADEON(0): Year: 2013  Week: 3
[    83.355] (II) RADEON(0): EDID Version: 1.3
[    83.355] (II) RADEON(0): Digital Display Input
[    83.355] (II) RADEON(0): Max Image Size [cm]: horiz.: 53  vert.: 30
[    83.355] (II) RADEON(0): Gamma: 2.20
[    83.355] (II) RADEON(0): DPMS capabilities: Off
[    83.355] (II) RADEON(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    83.355] (II) RADEON(0): Default color space is primary color space
[    83.355] (II) RADEON(0): First detailed timing is preferred mode
[    83.355] (II) RADEON(0): redX: 0.649 redY: 0.328   greenX: 0.330 greenY: 0.621
[    83.355] (II) RADEON(0): blueX: 0.150 blueY: 0.053   whiteX: 0.312 whiteY: 0.328
[    83.355] (II) RADEON(0): Supported established timings:
[    83.355] (II) RADEON(0): 720x400@70Hz
[    83.355] (II) RADEON(0): 640x480@60Hz
[    83.355] (II) RADEON(0): 640x480@75Hz
[    83.355] (II) RADEON(0): 800x600@60Hz
[    83.355] (II) RADEON(0): 800x600@75Hz
[    83.355] (II) RADEON(0): 832x624@75Hz
[    83.355] (II) RADEON(0): 1024x768@60Hz
[    83.355] (II) RADEON(0): 1024x768@75Hz
[    83.355] (II) RADEON(0): 1280x1024@75Hz
[    83.355] (II) RADEON(0): 1152x864@75Hz
[    83.355] (II) RADEON(0): Manufacturer's mask: 0
[    83.355] (II) RADEON(0): Supported standard timings:
[    83.355] (II) RADEON(0): #0: hsize: 640  vsize 480  refresh: 100  vid: 26673
[    83.355] (II) RADEON(0): #1: hsize: 640  vsize 480  refresh: 120  vid: 31793
[    83.355] (II) RADEON(0): #2: hsize: 800  vsize 600  refresh: 100  vid: 26693
[    83.355] (II) RADEON(0): #3: hsize: 800  vsize 600  refresh: 120  vid: 31813
[    83.355] (II) RADEON(0): #4: hsize: 1024  vsize 768  refresh: 100  vid: 26721
[    83.356] (II) RADEON(0): #5: hsize: 1024  vsize 768  refresh: 120  vid: 31841
[    83.356] (II) RADEON(0): #6: hsize: 1440  vsize 900  refresh: 120  vid: 15509
[    83.356] (II) RADEON(0): #7: hsize: 1920  vsize 1080  refresh: 60  vid: 49361
[    83.356] (II) RADEON(0): Supported detailed timing:
[    83.356] (II) RADEON(0): clock: 148.5 MHz   Image Size:  531 x 298 mm
[    83.356] (II) RADEON(0): h_active: 1920  h_sync: 2008  h_sync_end 2052 h_blank_end 2200 h_border: 0
[    83.356] (II) RADEON(0): v_active: 1080  v_sync: 1084  v_sync_end 1089 v_blanking: 1125 v_border: 0
[    83.356] (II) RADEON(0): Serial No: 51D01957SL0
[    83.356] (II) RADEON(0): Ranges: V min: 24 V max: 120 Hz, H min: 15 H max: 135 kHz, PixClock max 175 MHz
[    83.356] (II) RADEON(0): Monitor name: BenQ XL2411T
[    83.356] (II) RADEON(0): clock: 74.2 MHz   Image Size:  531 x 298 mm
[    83.356] (II) RADEON(0): v_active: 540  v_sync: 542  v_sync_end 547 v_blanking: 562 v_border: 0
[    83.356] (II) RADEON(0): h_active: 1280  h_sync: 1390  h_sync_end 1430 h_blank_end 1650 h_border: 0
[    83.356] (II) RADEON(0): v_active: 720  v_sync: 725  v_sync_end 730 v_blanking: 750 v_border: 0
[    83.356] (II) RADEON(0): clock: 27.0 MHz   Image Size:  531 x 298 mm
[    83.356] (II) RADEON(0): h_active: 720  h_sync: 736  h_sync_end 798 h_blank_end 858 h_border: 0
[    83.356] (II) RADEON(0): v_active: 480  v_sync: 489  v_sync_end 495 v_blanking: 525 v_border: 0
[    83.356] (II) RADEON(0): Number of EDID sections to follow: 1
[    83.356] (II) RADEON(0): EDID (in hex):
[    83.356] (II) RADEON(0): 	00ffffffffffff0009d1117f45540000
[    83.356] (II) RADEON(0): 	0317010380351e782e48a0a654549f26
[    83.356] (II) RADEON(0): 	0d5054a56b803168317c4568457c6168
[    83.356] (II) RADEON(0): 	617c953cd1c0023a801871382d40582c
[    83.356] (II) RADEON(0): 	4500132a2100001e000000ff00353144
[    83.356] (II) RADEON(0): 	3031393537534c300a20000000fd0018
[    83.356] (II) RADEON(0): 	780f8711000a202020202020000000fc
[    83.356] (II) RADEON(0): 	0042656e5120584c32343131540a0152
[    83.356] (II) RADEON(0): 	020323f1509005040302011112131406
[    83.356] (II) RADEON(0): 	0715161f20230907078301000065030c
[    83.356] (II) RADEON(0): 	001200011d8018711c1620582c250013
[    83.356] (II) RADEON(0): 	2a2100009f011d007251d01e206e2855
[    83.356] (II) RADEON(0): 	00132a2100001f8c0ad08a20e02d1010
[    83.356] (II) RADEON(0): 	3e9600132a2100001900000000000000
[    83.356] (II) RADEON(0): 	00000000000000000000000000000000
[    83.356] (II) RADEON(0): 	000000000000000000000000000000f5
[    83.356] (--) RADEON(0): HDMI max TMDS frequency 145000KHz
[    83.357] (II) RADEON(0): Not using mode "1440x900" (bad mode clock/interlace/doublescan)
[    83.357] (II) RADEON(0): Printing probed modes for output DisplayPort-1
[    83.357] (II) RADEON(0): Modeline "1920x1080"x60.0  148.50  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.5 kHz eP)
[    83.357] (II) RADEON(0): Modeline "1920x1080"x50.0  148.50  1920 2448 2492 2640  1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[    83.357] (II) RADEON(0): Modeline "1920x1080"x59.9  148.35  1920 2008 2052 2200  1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[    83.357] (II) RADEON(0): Modeline "1920x1080i"x60.0   74.25  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[    83.357] (II) RADEON(0): Modeline "1920x1080i"x50.0   74.25  1920 2448 2492 2640  1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[    83.357] (II) RADEON(0): Modeline "1920x1080"x24.0   74.25  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[    83.357] (II) RADEON(0): Modeline "1920x1080i"x59.9   74.18  1920 2008 2052 2200  1080 1084 1094 1125 interlace +hsync +vsync (33.7 kHz e)
[    83.357] (II) RADEON(0): Modeline "1920x1080"x24.0   74.18  1920 2558 2602 2750  1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[    83.357] (II) RADEON(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    83.357] (II) RADEON(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    83.357] (II) RADEON(0): Modeline "1280x720"x60.0   74.25  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    83.357] (II) RADEON(0): Modeline "1280x720"x50.0   74.25  1280 1720 1760 1980  720 725 730 750 +hsync +vsync (37.5 kHz e)
[    83.357] (II) RADEON(0): Modeline "1280x720"x59.9   74.18  1280 1390 1430 1650  720 725 730 750 +hsync +vsync (45.0 kHz e)
[    83.357] (II) RADEON(0): Modeline "1024x768"x120.0  115.50  1024 1072 1104 1184  768 771 775 813 +hsync -vsync (97.6 kHz e)
[    83.357] (II) RADEON(0): Modeline "1024x768"x100.0  113.27  1024 1096 1208 1392  768 769 772 814 -hsync +vsync (81.4 kHz)
[    83.357] (II) RADEON(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    83.357] (II) RADEON(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    83.357] (II) RADEON(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    83.357] (II) RADEON(0): Modeline "800x600"x120.0   73.25  800 848 880 960  600 603 607 636 +hsync -vsync (76.3 kHz e)
[    83.357] (II) RADEON(0): Modeline "800x600"x100.0   68.17  800 848 936 1072  600 601 604 636 -hsync +vsync (63.6 kHz)
[    83.357] (II) RADEON(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    83.357] (II) RADEON(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    83.357] (II) RADEON(0): Modeline "720x576"x50.0   27.00  720 732 796 864  576 581 586 625 -hsync -vsync (31.2 kHz e)
[    83.357] (II) RADEON(0): Modeline "720x576i"x50.0   13.50  720 732 795 864  576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[    83.357] (II) RADEON(0): Modeline "720x480"x60.0   27.03  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    83.357] (II) RADEON(0): Modeline "720x480"x59.9   27.00  720 736 798 858  480 489 495 525 -hsync -vsync (31.5 kHz e)
[    83.357] (II) RADEON(0): Modeline "720x480i"x60.0   13.51  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.8 kHz e)
[    83.357] (II) RADEON(0): Modeline "720x480i"x59.9   13.50  720 739 801 858  480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[    83.357] (II) RADEON(0): Modeline "640x480"x120.0   52.40  640 680 744 848  480 481 484 515 -hsync +vsync (61.8 kHz)
[    83.357] (II) RADEON(0): Modeline "640x480"x100.0   43.16  640 680 744 848  480 481 484 509 -hsync +vsync (50.9 kHz)
[    83.357] (II) RADEON(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    83.357] (II) RADEON(0): Modeline "640x480"x60.0   25.20  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    83.357] (II) RADEON(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    83.357] (II) RADEON(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    83.378] (II) RADEON(0): EDID for output DisplayPort-2
[    83.399] (II) RADEON(0): EDID for output DisplayPort-3
[    83.399] (II) RADEON(0): Output DisplayPort-0 disconnected
[    83.399] (II) RADEON(0): Output DisplayPort-1 connected
[    83.399] (II) RADEON(0): Output DisplayPort-2 disconnected
[    83.399] (II) RADEON(0): Output DisplayPort-3 disconnected
[    83.399] (II) RADEON(0): Using exact sizes for initial modes
[    83.399] (II) RADEON(0): Output DisplayPort-1 using initial mode 1920x1080 +0+0
[    83.399] (II) RADEON(0): mem size init: gart size :3fdce000 vram size: s:80000000 visible:f4b4000
[    83.399] (II) RADEON(0): EXA: Driver will allow EXA pixmaps in VRAM
[    83.399] (==) RADEON(0): DPI set to (96, 96)
[    83.399] (==) RADEON(0): Using gamma correction (1.0, 1.0, 1.0)
[    83.399] (II) Loading sub module "ramdac"
[    83.399] (II) LoadModule: "ramdac"
[    83.399] (II) Module "ramdac" already built-in
[    83.400] (==) FBDEV(1): Depth 24, (==) framebuffer bpp 32
[    83.400] (==) FBDEV(1): RGB weight 888
[    83.400] (==) FBDEV(1): Default visual is TrueColor
[    83.400] (==) FBDEV(1): Using gamma correction (1.0, 1.0, 1.0)
[    83.400] (II) FBDEV(1): hardware: radeondrmfb (video memory: 14400kB)
[    83.400] (II) FBDEV(1): checking modes against framebuffer device...
[    83.400] (II) FBDEV(1): checking modes against monitor...
[    83.400] (II) FBDEV(1): Virtual size is 2560x1440 (pitch 2560)
[    83.400] (**) FBDEV(1):  Built-in mode "current"
[    83.400] (==) FBDEV(1): DPI set to (96, 96)
[    83.400] (II) Loading sub module "fb"
[    83.400] (II) LoadModule: "fb"
[    83.400] (II) Module "fb" already built-in
[    83.400] (**) FBDEV(1): using shadow framebuffer
[    83.400] (II) Loading sub module "shadow"
[    83.400] (II) LoadModule: "shadow"
[    83.400] (II) Loading /usr/lib/xorg/modules/libshadow.so
[    83.400] (II) Module shadow: vendor="X.Org Foundation"
[    83.400] 	compiled for 1.21.1.7, module version = 1.1.0
[    83.400] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    83.401] (II) RADEON(0): [DRI2] Setup complete
[    83.401] (II) RADEON(0): [DRI2]   DRI driver: r600
[    83.401] (II) RADEON(0): [DRI2]   VDPAU driver: r600
[    83.401] (II) RADEON(0): Front buffer size: 8100K
[    83.401] (II) RADEON(0): VRAM usage limit set to 218142K
[    83.401] (==) RADEON(0): DRI3 disabled
[    83.401] (==) RADEON(0): Backing store enabled
[    83.401] (II) RADEON(0): Direct rendering enabled
[    83.401] (II) EXA(0): Driver allocated offscreen pixmaps
[    83.401] (II) EXA(0): Driver registered support for the following operations:
[    83.401] (II)         Solid
[    83.401] (II)         Copy
[    83.401] (II)         Composite (RENDER acceleration)
[    83.402] (II)         UploadToScreen
[    83.402] (II)         DownloadFromScreen
[    83.402] (II) RADEON(0): Acceleration enabled
[    83.402] (==) RADEON(0): DPMS enabled
[    83.402] (==) RADEON(0): Silken mouse enabled
[    83.402] (II) RADEON(0): Set up textured video
[    83.402] (II) RADEON(0): [XvMC] Associated with Radeon Textured Video.
[    83.402] (II) RADEON(0): [XvMC] Extension initialized.
[    83.465] (==) FBDEV(1): Backing store enabled
[    83.465] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[    83.466] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[    83.467] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[    83.468] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[    83.469] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[    83.470] (EE) FBDEV(1): FBIOPUTCMAP: Invalid argument
[    83.470] (==) FBDEV(1): DPMS enabled
[    83.470] (II) Initializing extension Generic Event Extension
[    83.471] (II) Initializing extension SHAPE
[    83.471] (II) Initializing extension MIT-SHM
[    83.472] (II) Initializing extension XInputExtension
[    83.473] (II) Initializing extension XTEST
[    83.473] (II) Initializing extension BIG-REQUESTS
[    83.474] (II) Initializing extension SYNC
[    83.475] (II) Initializing extension XKEYBOARD
[    83.475] (II) Initializing extension XC-MISC
[    83.476] (II) Initializing extension SECURITY
[    83.477] (II) Initializing extension XFIXES
[    83.477] (II) Initializing extension RENDER
[    83.478] (II) Initializing extension RANDR
[    83.479] (II) Initializing extension COMPOSITE
[    83.480] (II) Initializing extension DAMAGE
[    83.480] (II) Initializing extension MIT-SCREEN-SAVER
[    83.481] (II) Initializing extension DOUBLE-BUFFER
[    83.482] (II) Initializing extension RECORD
[    83.482] (II) Initializing extension DPMS
[    83.483] (II) Initializing extension Present
[    83.484] (II) Initializing extension DRI3
[    83.484] (II) Initializing extension X-Resource
[    83.484] (II) Initializing extension XVideo
[    83.485] (II) Initializing extension XVideo-MotionCompensation
[    83.486] (II) Initializing extension SELinux
[    83.486] (II) SELinux: Disabled on system
[    83.486] (II) Initializing extension GLX
[    83.504] (II) AIGLX: Loaded and initialized r600
[    83.504] (II) GLX: Initialized DRI2 GL provider for screen 0
[    83.504] (II) AIGLX: Screen 1 is not DRI2 capable
[    83.706] (II) IGLX: Loaded and initialized swrast
[    83.706] (II) GLX: Initialized DRISWRAST GL provider for screen 1
[    83.707] (II) Initializing extension XFree86-VidModeExtension
[    83.707] (II) Initializing extension XFree86-DGA
[    83.708] (II) Initializing extension XFree86-DRI
[    83.708] (II) Initializing extension DRI2
[    83.709] (II) RADEON(0): Setting screen physical size to 508 x 285
[    83.942] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/event0)
[    83.943] (**) ATEN HDMI KVM: Applying InputClass "libinput keyboard catchall"
[    83.943] (II) LoadModule: "libinput"
[    83.943] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[    83.948] (II) Module libinput: vendor="X.Org Foundation"
[    83.948] 	compiled for 1.21.1.3, module version = 1.2.1
[    83.948] 	Module class: X.Org XInput Driver
[    83.948] 	ABI class: X.Org XInput driver, version 24.4
[    83.948] (II) Using input driver 'libinput' for 'ATEN HDMI KVM'
[    83.949] (**) ATEN HDMI KVM: always reports core events
[    83.949] (**) Option "Device" "/dev/input/event0"
[    83.959] (II) event0  - ATEN HDMI KVM: is tagged by udev as: Keyboard
[    83.959] (II) event0  - ATEN HDMI KVM: device is a keyboard
[    83.960] (II) event0  - ATEN HDMI KVM: device removed
[    83.970] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.0/0003:0557:222E.0001/input/input0/event0"
[    83.970] (II) XINPUT: Adding extended input device "ATEN HDMI KVM" (type: KEYBOARD, id 6)
[    83.970] (**) Option "xkb_model" "pc105"
[    83.970] (**) Option "xkb_layout" "us"
[    83.976] (II) event0  - ATEN HDMI KVM: is tagged by udev as: Keyboard
[    83.976] (II) event0  - ATEN HDMI KVM: device is a keyboard
[    83.979] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/event1)
[    83.979] (**) ATEN HDMI KVM: Applying InputClass "libinput pointer catchall"
[    83.979] (II) Using input driver 'libinput' for 'ATEN HDMI KVM'
[    83.979] (**) ATEN HDMI KVM: always reports core events
[    83.979] (**) Option "Device" "/dev/input/event1"
[    84.035] (II) event1  - ATEN HDMI KVM: is tagged by udev as: Mouse
[    84.036] (II) event1  - ATEN HDMI KVM: device is a pointer
[    84.036] (II) event1  - ATEN HDMI KVM: device removed
[    84.066] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.1/0003:0557:222E.0002/input/input1/event1"
[    84.066] (II) XINPUT: Adding extended input device "ATEN HDMI KVM" (type: MOUSE, id 7)
[    84.066] (**) Option "AccelerationScheme" "none"
[    84.066] (**) ATEN HDMI KVM: (accel) selected scheme none/0
[    84.066] (**) ATEN HDMI KVM: (accel) acceleration factor: 2.000
[    84.066] (**) ATEN HDMI KVM: (accel) acceleration threshold: 4
[    84.122] (II) event1  - ATEN HDMI KVM: is tagged by udev as: Mouse
[    84.123] (II) event1  - ATEN HDMI KVM: device is a pointer
[    84.125] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/mouse0)
[    84.125] (II) No input driver specified, ignoring this device.
[    84.125] (II) This device may have been added with another device file.
[    84.128] (II) config/udev: Adding input device ATEN HDMI KVM Keyboard (/dev/input/event2)
[    84.128] (**) ATEN HDMI KVM Keyboard: Applying InputClass "libinput keyboard catchall"
[    84.128] (II) Using input driver 'libinput' for 'ATEN HDMI KVM Keyboard'
[    84.128] (**) ATEN HDMI KVM Keyboard: always reports core events
[    84.128] (**) Option "Device" "/dev/input/event2"
[    84.134] (II) event2  - ATEN HDMI KVM Keyboard: is tagged by udev as: Keyboard
[    84.134] (II) event2  - ATEN HDMI KVM Keyboard: device is a keyboard
[    84.134] (II) event2  - ATEN HDMI KVM Keyboard: device removed
[    84.142] (II) libinput: ATEN HDMI KVM Keyboard: needs a virtual subdevice
[    84.142] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.2/0003:0557:222E.0003/input/input2/event2"
[    84.142] (II) XINPUT: Adding extended input device "ATEN HDMI KVM Keyboard" (type: MOUSE, id 8)
[    84.142] (**) Option "AccelerationScheme" "none"
[    84.142] (**) ATEN HDMI KVM Keyboard: (accel) selected scheme none/0
[    84.142] (**) ATEN HDMI KVM Keyboard: (accel) acceleration factor: 2.000
[    84.142] (**) ATEN HDMI KVM Keyboard: (accel) acceleration threshold: 4
[    84.147] (II) event2  - ATEN HDMI KVM Keyboard: is tagged by udev as: Keyboard
[    84.148] (II) event2  - ATEN HDMI KVM Keyboard: device is a keyboard
[    84.151] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/event3)
[    84.151] (**) ATEN HDMI KVM: Applying InputClass "libinput pointer catchall"
[    84.151] (II) Using input driver 'libinput' for 'ATEN HDMI KVM'
[    84.151] (**) ATEN HDMI KVM: always reports core events
[    84.151] (**) Option "Device" "/dev/input/event3"
[    84.206] (II) event3  - ATEN HDMI KVM: is tagged by udev as: Mouse
[    84.207] (II) event3  - ATEN HDMI KVM: device is a pointer
[    84.207] (II) event3  - ATEN HDMI KVM: device removed
[    84.228] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.3/0003:0557:222E.0004/input/input3/event3"
[    84.228] (II) XINPUT: Adding extended input device "ATEN HDMI KVM" (type: MOUSE, id 9)
[    84.228] (**) Option "AccelerationScheme" "none"
[    84.228] (**) ATEN HDMI KVM: (accel) selected scheme none/0
[    84.228] (**) ATEN HDMI KVM: (accel) acceleration factor: 2.000
[    84.228] (**) ATEN HDMI KVM: (accel) acceleration threshold: 4
[    84.284] (II) event3  - ATEN HDMI KVM: is tagged by udev as: Mouse
[    84.285] (II) event3  - ATEN HDMI KVM: device is a pointer
[    84.288] (II) config/udev: Adding input device ATEN HDMI KVM (/dev/input/mouse1)
[    84.288] (II) No input driver specified, ignoring this device.
[    84.288] (II) This device may have been added with another device file.
[    84.302] (**) ATEN HDMI KVM Keyboard: Applying InputClass "libinput keyboard catchall"
[    84.302] (II) Using input driver 'libinput' for 'ATEN HDMI KVM Keyboard'
[    84.302] (**) ATEN HDMI KVM Keyboard: always reports core events
[    84.302] (**) Option "Device" "/dev/input/event2"
[    84.302] (II) libinput: ATEN HDMI KVM Keyboard: is a virtual subdevice
[    84.302] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:11.0/0000:05:13.5/usb3/3-1/3-1.1/3-1.1.3/3-1.1.3.1/3-1.1.3.1:1.2/0003:0557:222E.0003/input/input2/event2"
[    84.302] (II) XINPUT: Adding extended input device "ATEN HDMI KVM Keyboard" (type: KEYBOARD, id 10)
[    84.302] (**) Option "xkb_model" "pc105"
[    84.302] (**) Option "xkb_layout" "us"
[   104.806] (II) event0  - ATEN HDMI KVM: device removed
[   104.816] (II) event1  - ATEN HDMI KVM: device removed
[   104.830] (II) event3  - ATEN HDMI KVM: device removed
[   104.844] (II) event2  - ATEN HDMI KVM Keyboard: device removed
[   104.850] (II) AIGLX: Suspending AIGLX clients for VT switch
[   128.827] (II) UnloadModule: "libinput"
[   128.828] (II) UnloadModule: "libinput"
[   128.829] (II) UnloadModule: "libinput"
[   128.860] (II) Server terminated successfully (0). Closing log file.
P.S. tested on Debian Sid/12.0 + kernel 6.12.76
and Debian 8 + kernel 5.5 ( same black screen, slighty different logs )
