Minor error in Autodocs arexx_cl.doc.txt
Report errors, omissions, etc. regarding the AmigaOS Documentation Wiki here.
OldFart
Post by OldFart »
Under the tag:
AREXX_Commands (struct ARexxCmd *)
this description for member ac_Func is given:
ac_Func (*()(struct ARexxCmd *, struct RexxMsg *))
	        A pointer to the function that will be called when this
	        command is received by your programme. The function will
	        get past a pointer to its ARexxCmd entry and the RexxMsg
	        structure received for the command. You may use this
	        for setting ARexx variables but please note that it may
	        be NULL.
I think this should read:
	        get passed a pointer to its ARexxCmd entry and the RexxMsg
	        be NULL.
The error is in the word 'past' vs 'passed'.
Btw, apart from 'bots' is anyone else paying any attention to these 'detections'?
OldFart
X5000, appears to be sick. Dismantled jan 1, 2024.
Dead MicroA1
RaspBerry Pi 2B, 3B, 4B/4Gb, 4B/8Gb
OrangePi 5+ 8Gb
ACER Windows 10
Re: Minor error in Autodocs arexx_cl.doc.txt
Thanks, bug report made in Bugzilla.
BTW, the file in question is arexx_cl.doc, not arexx_cl.doc.txt.
colinw
Post by colinw »
You can close the bug report Niels, I just fixed the source code document,
so the next time the docs are regenerated, the typo will be gone.
Thanks.
I set it to fixed, verification and closure will have to wait until next time it's built for beta.
(So now all we need is somebody finding a bug in the actual class ;-)).
OldFart
Post by OldFart »
@nbache:
The title in my browser reads:
@collinw & nbache
Thanks for the action undertaken.
OldFart
Dead MicroA1
OrangePi 5+ 8Gb
ACER Windows 10
