Level 3 cache not detected
Corporal Up The Nuts
Post by Corporal Up The Nuts »
My G4 cpu module has the two CY7C1354BV25-166AXC SRAM chips installed, but neither Ranger and Sysmon is able to detect it.
I've heard that early in the production of the A1XE that they removed the cache to save costs, but does AmigaOS also disable it since then?
Any way to re-enable it?
sailorMH
Re: Level 3 cache not detected
Post by sailorMH »
I am not sure, but it can be caused by this:
AmigaOne XE and Micro A1-C had Southbridge Articia-S with cache coherency bug. There is software workaround in OS. It is possible, that it also turns off L3. Try to search for Articia S cache coherency or ask directly developers.
Long time ago now, but back in 2004 I do remember the kernel developers saying that the Level 3 cache had little or no effect, and was disabled because of that.
sailorMH
Post by sailorMH »
I know, I am replying to older topics.
But if L3 cache on our G4 modules are disabled by developers decision that L3 has no effect, it is not exact.
L3 has in real world great effect for certain tasks: There https://www.amigaportal.cz/node/162841 is mine + ervus@macrumors article about L1-L3 caches in powerpc G3-G5 CPUs, with measuring of G4 L3 cache size influence from ervus and G3 L2 cache size influence from me. Results are very impressive.
Article is in Czech language, so please use google translate.
So, if L3 cache on our modules is only switched-off, I plead for enabling of L3, it is great.
But if it caused by ArticiaS cache coherency problem, it is a pitty, we cannot do nothing.
Hypex
Post by Hypex »
I wonder then if it's still enabled in Linux?
sailorMH
Post by sailorMH »
Hypex wrote: Sun Jul 02, 2023 2:04 pm I wonder then if it's still enabled in Linux?
Unfortunatelly, even L2 is disabled - probably it "solves" cache coherency problem:
root@xe:/home/martina# lshw
xe
    description: Computer
    product: AmigaOne
    width: 32 bits
  *-core
       description: Motherboard
       physical id: 0
       capabilities: eyetech_amigaone
     *-cpu
          description: CPU
          product: 7455, altivec supported
          physical id: 0
          bus info: cpu@0
          version: 3.3 (pvr 8001 0303)
          clock: 133MHz
        *-cache
             description: L1 Cache
             physical id: 0
root@xe:/home/martina# lscpu
Architecture:          ppc
CPU op-mode(s):        32-bit
Byte Order:            Big Endian
CPU(s):                1
On-line CPU(s) list:   0
Thread(s) per core:    1
Core(s) per socket:    1
Socket(s):             1
Vendor ID:             Eyetech Ltd.
Model:                 AmigaOne
BogoMIPS:              66.66
L1d cache:             32K
L1i cache:             32K
P.S.: 400MHz is a (probably firmware) bug - it shows 400, but in real it is 1400 MHz.
Hypex
Post by Hypex »
sailorMH wrote: Sun Aug 27, 2023 7:26 pm Unfortunatelly, even L2 is disabled - probably it "solves" cache coherency problem:
Well that would. But it tends to be on for an XE. For example, if radeon module uses acceleration, it will freeze up as cache is activated normally.
It is strange getting the CPU clock wrong. Though checking out lshw I've seen "size" for base speed and 'capacity" for max speed. So I wonder perhaps if it estimated a base and not a nominal speed.
sailorMH
Post by sailorMH »
Hypex wrote: Mon Aug 28, 2023 4:13 pm But it tends to be on for an XE. For example, if radeon module uses acceleration, it will freeze up as cache is activated normally.
And is possible to enable L2 with some kernel parameter? Like l2cr or cachesize= ? Or is it done by parameters during kernel compilation?
Hypex wrote: It is strange getting the CPU clock wrong. Though checking out lshw I've seen "size" for base speed and 'capacity" for max speed. So I wonder perhaps if it estimated a base and not a nominal speed.
Yes, it is strange. I have no simple answer, but higher frequencies ( with PLL_CFG_4 = 1 ) shows false CPU frequency. U-Boot, AmigaOS and linux also.
1400 MHz shows like 400 MHz
1533 MHz shows like 66 MHz, i.e. like value with PLL_CFG_4 = 0
But CPU speed is high for sure.
I tried other UBoot versions, but every shows false speed. Maybe is it caused by my 7455 CPU? Evillords's 7457 shows 1533 normally.
Here https://www.amigaportal.cz/node/161812 ( Czech language ) is my experiences with AmigaOne XE CPU exchange and overclock.
Generally, it is not big problem, XE is fast now.
I am suspicious about UBoot. MacMini has the same problem with heavy overclocking, some OF variables must be modified to show correct frequency.
sailorMH
Post by sailorMH »
I checked commandline kernel parameters, and there are l2cr=0x80000000
My 7455 has 256 kB L2, i.e. 0x40000 and 0x80000000 is 2 GB...
Unfortunatelly, I am not find what does this mean. I can try l2cr=0x40000....
P.S. if l2cr kernel parameter set the L2CR CPU register ( L2 control register ), setting of this is too complex for me.. Chapter 2.2.5.5 of MPC7450 RISC Microprocessor Family Reference Manual https://www.nxp.com/docs/en/reference-m ... 7450UM.pdf :-(
sailorMH
Post by sailorMH »
After quick look on manual, the most simple setting of l2cr should be:
l2cr=3 .. i.e. 11B
it means L2 cache is enabled + L2 parity checking enabled
But, kernel parameter meaning should differ from CPU l2cr register and maybe other L2 parameters should be set. But this I don't understand.
I will try l2cr=3 on weekend and we will see.
