Using svg datatype
yoodoo2
Using svg datatype
Post by yoodoo2 »
Does anyone have a simple example of how to use datatypes to load and display a svg file into a rastport? I'm getting ERROR 2000 returned from the following code, which worked up to about update 3, iirc
if (o=IDataTypes->NewDTObject((APTR)filename, NULL))
         DTA_SourceType,         DTST_FILE,
           DTA_GroupID,            GID_PICTURE,
          PDTA_Remap,             TRUE,
           PDTA_Screen,            screen,
          PDTA_FreeSourceBitMap,  TRUE,
           PDTA_DestMode,          PMODE_V43,
           PDTA_UseFriendBitMap,   TRUE,
           OBP_Precision,          PRECISION_IMAGE,
         TAG_DONE))
	drawinfo = IDataTypes->ObtainDTDrawInfoA(o, TAG_DONE);
	IDataTypes->DrawDTObjectA(drawspacewindow->RPort, o,  startx, starty, width, height, 0, 0, TAG_DONE);
	IDataTypes->ReleaseDTDrawInfo(o, drawinfo);
	IDataTypes->DisposeDTObject(o);
Re: Using svg datatype
Which SVG datatype are you using? There are at least two - one is a subclass of picture.datatype, and the other is a subclass of drawing.datatype.
If you've changed from using one to the other, then the problem is likely just this tag:
That's restricting you to picture.datatype subclasses, so remove it.
If you need the drawing.datatype includes let me know and I'll add you to the project, but it shouldn't be necessary unless you're creating a subclass.
yoodoo2
Post by yoodoo2 »
It certainly doesn't work with your version, 53.1, but I believe it stopped working with earlier versions from salass (52?) too.
Any idea what the error code 2000 means? Can't find it in the includes.
Post by thomasrapp »
yoodoo2 wrote:Any idea what the error code 2000 means? Can't find it in the includes.
Use GetDTString(2000) to get the message text.
salass00
Post by salass00 »
yoodoo2 wrote: Any idea what the error code 2000 means? Can't find it in the includes
At end of <datatypes/datatypes.h>:
#define DTERROR_UNKNOWN_DATATYPE 2000
It means that it wasn't recognised as a supported format by any of the datatype descriptors installed on the system. Either you forgot to install the SVG descriptor file in DEVS:DataTypes or the file is just not being recognised as an SVG file (maybe because it's compressed?).
salass00 wrote:It means that it wasn't recognised as a supported format by any of the datatype descriptors installed on the system. Either you forgot to install the SVG descriptor file in DEVS:DataTypes or the file is just not being recognised as an SVG file (maybe because it's compressed?).
Or because it's not a GID_PICTURE datatype...
@yoodoo2
If it doesn't work with either, it might be a problem with the descriptor, as IIRC I used salass00's descriptor for my SVG datatype.
Can you open the file with MultiView?
yoodoo2
Post by yoodoo2 »
Hmm, something odd going on here. Some of the svg files I use for testing did load in Multiview a few days ago, but now they don't. They all load fine in both OWB and NetSurf.
I must have messed something up here somehow.
