Add command to Workbench contextual menu ?
Post by zzd10h »
Is somebody knows if it's possible to add a command to the
Workbench contextual menu (when you click the RMB and the menu 'Workbench /
Execute command / Open a drawer /... appeared).
Thanks for your reply.
Re: Add command to Workbench contextual menu ?
zzd10h wrote:Hi,
Yes it is. The information you need is in Documentation/Commodities/ContextMenus.doc.
Post by zzd10h »
Great,
Thank a lot.
